akif tekin
When I open the program, a warning appears as in the picture. There is a problem in the program, I turn off the warning and continue to work, but there was no such warning before.
"KUBA2009":1cgcvf64" said:In 6.053, when we want to open the drawings we made in the previous ide 5 version, it gives the message Incompatible file. Use an updated program version to open this file. Can you add it to the message? Good work...
We did not encounter the problem you mentioned. ."KUBA2009":3h05gpxm" said:In 6.053, when we want to open the drawings we made in the previous ide 5 version, it gives an incompatible file. Use an updated program version to open this file. It gives the message
Hello, If these two walls are drawn with the curved wall command, a corner window can be placed. In the Wall Settings/Advanced Settings tab Give the curved wall point number 1. Click the curved wall command from the wall assistant toolbar and draw your corner wall. After selecting the window you want to place in the door window settings, mark the curved door/window line from the Type section. Place your window on the wall. Good work"akif tekin":3vt9vin3" said:greetings, I cannot place a window on the corner wall in the picture with the tilted window option.
Hello In Settings Menu/General Settings Dialog -OpenGL use hardware accelerator - can you uncheck the line and try again after closing and reopening the program?"akif tekin":1ewuiklu" said:greetings, I started having problems after installing version 6.53. It gives the error shown in the picture and it closes.
