Arzu Dural Gök
Re: how does the tax-kaks report work When you enter the tax-kaks report command in the program, land area, taks (floor area coefficient) and kaks (floor area coefficient) are entered. In the generated report, the total sitting area (floor area) is calculated on the land. It is checked whether this field exceeds the tax value. In addition, the area of all floors is calculated. It is checked whether it exceeds the Kaks value. Let me explain with a numerical example: Let the land area be 300 m2 and the tax value 0.5, the kax value 1.5. The residential area of your building is calculated automatically. eg. Let's say 175 m2 is found.. You can make a building with a floor area of 150 m2 from 300x0.5. You can see from the report that you need to reduce the value of 175 m2. You can build a total construction area of 450 m2 from 300x1.5 kaks. The program calculates all your floor areas and writes them to the report. You can easily determine the design by comparing this value with 450 m2. You choose which locations will be taken into account in the tax-kaks report from the location settings. For example, for your terraces sitting on the land, you should enter the location settings and tick the checkbox to add to the tax report - to add to the tax report. In the settings of your spaces only on the ground floor (floor on the ground), adding to the taxi and taxi report should be passive (participate). Spaces on all other floors should be included in the kaks report only. It should be marked as added to the tax report. Good work...
