Hello Creating the roof We saw that there are millimetric deviations at the points you used for the roof eaves, we defined axes to the roof eaves points and reconstructed the roof using these points.The project and the screenshot are attached The project is in ideCAD Architectural Enterprise 5.511 IDS Format Good work"erturan":d074z0w0" said:why is the roof not visible as I have attached? In the plan, the roof does not appear completely in perspective, half of it is visible. (version 5.511)
You can create the ceramic coating surface of the balcony with the Hello Space command and the ceiling of the balcony with the Reinforced concrete floor you will create in the mold plan. You can define separate materials for both. If you wish, you can close the side surfaces of the balcony by using the floor deletion or profile object command, You can give the exterior material color to the object.You can check the attached file Balkon.ide6 (ideCAD Architecture 6.01 Vers.) Good work."teknick":1o2mshew" said:When we want to paint the balconies in a different color on the exterior, the floor of the balcony is in a different color because of the flooring. Likewise, I want to make the balcony ceilings a different color .. how can we do this?
Hello You can divide overlapping walls with the Extend wall / divide command.You can use this command from the vertical toolbar on the left of the screen or from the Change menu - You can access it by using ->Object Edit -->Wall menu.You can use this command to intersect by extending the wall to another wall without changing its angle."teknick":3nmv6eye" said:..... Also, when we make the "Divide by Intersections" option active while drawing the walls, it divides the walls we draw at the intersection points and combines them. This is really nice. Well, when we copy or clone objects, we also divide the overlapping walls by intersections. This is really important because... ...
Hi, press Ctrl. If you create a selection window with the mouse, the selected objects become unselected."erturan":1sbvcnom" said:I cannot remove the objects I selected with the selection window using the selection window again? This problem did not exist in ide 5.511, it started in ide 6.
