"akif tekin":3go7gxhy" said:
hi, I have some problems with the program that I could not solve. 1-the program crashes very often and closes 2-when I use trees in rendering, rendering becomes impossible 3-although I get excellent results in some rendering works, the rendering is very bad in some renderings, I could not understand the reason for this. For example, I want to make a column, put a round column and a straight column. we can do it in the form of..but I want to have a title on the foot under the column. I want embroideries on the body or something.. I can do these with auxiliary objects, but it takes a lot of time and I can't make the columns I want... my suggestion, can't we add a section called columns to the library? good work...
1-
2-Library Writes the dimensions of the libraries in the settings. If you have too many trees in your scene, you should choose trees closer to the camera with more detail (larger file size) and those in the background with less detail (smaller size). This rule applies to all rendering engines and should be considered for efficient operation. If animation will not be prepared, it will be better to use opaque trees instead of using 3d trees. (or hybrid) see:
3-Successful results of our rendering engine it is medium.
Some of your work, although excellent results, The bad results are because you didn't prepare those scenes well for rendering. There is no rule that everyone can render well. Getting a good render is a process... Mastering the program, mastering the architecture, a good architectural facade/stage, using the right materials, having aesthetic tastes, trying again and again until you get good results, and working until you gain experience, as in any job. directly related to self-development. Post some of the scenes where you didn't succeed. Let's give our recommendations. Make your adjustments accordingly and continue working on it. 4- Using the rotated and extended object in the link below, you can create columns, steel roofs, buttresses, etc. You will find sample projects that you can do. By examining them, you can easily model the object you want. If you want more branched rose column titles, it is possible to download 3ds from the site suggested by Mr. Yaşar or from similar sites and make a library. Although you wrote that you know both of these methods. You said it takes a lot of time. It certainly won't take much time. We're talking about a few minutes transactions. Can several types be added to the library, of course it is added. In the coming days, we will add it and share it on the forum, but you will not find everything you want in the program library. If we add something else, you will want to use something else. Long story short, it is not a very correct approach to think that it takes a long time. If you want to create something special, you should not hesitate to spare a few minutes. While the program has made both free modeling and file transfer possible, not making use of them and trying to use everything from ready-made types limits the design and therefore the architectural project. Sincerely
