Zeynep Aladağ
Member
Hello, when you select the tile you want to bevel to and click the right mouse button in the Bevel objects command, the program will show you "Objects connected to the tile. Would you like to choose it too?" will ask. If you choose no, only the flooring you selected will be sloped. The program will slope based on the first point of your reference line, which determines your slope direction. For one edge of the tile to be fixed, you must define the first point of your reference line on the edge of the tile you want to be fixed. Good work..."vforvendett4":1zg0muxf" said:Sir, in the same situation, column lengths will be constant. one of the beams is at -150 cm elevation. The other two are connected to this beam inclined from +0 to -150. (I handle the beams). But this time the back part is lifted when I give -150 jeans to that floor. Is it possible to give a level of -150 only to one side of the tile with a fixed edge?"Zeynep Aladağ":1zg0muxf" said:You can tilt your tiles with the "Bevel Objects" command from the tiling toolbar. To give slope to your flooring; - Click the Bevel objects icon from the tiling toolbar. - Select the tile you want to bevel and click the right mouse button. - Select/not select the objects around the tile from the dialog. - Draw your direction to determine the direction of the slope. - Adjust your settings in the Tilt options dialog.
