Hi,
"hakan":r6avl2y7" said:
I can't fix it when I got a wrong spot. I have to resize it again. Is there a solution?
You need to delete it and resize it.
And when the pattern plans are printed, the points that are kept are shown with circles. why can't we print them with notation...
Yes, we can't make a selection in the pattern plan as the measurement points are circles. However, in the column application plan, the measurement separator line is used. You can use the axis system for the formwork plan by copy-pasting from the column application. Good work...
