Re: ideCAD Statik 6.51 Beta new version Mrb I had a question, how can we analyze masonry structures in ideCAD Statik 6.51 Beta new version. In my opinion, if I model the panel as a shell and take the elasticity module as the factory brick module, what will we do with the mortar? Also, do we need to change the elasticity module in the reinforcement steel, that is, enter the elasticity module of the brick? Of course, will there be such a situation as if we will enter the poisson ratios? that is, if we use the entrance as a single composite material whose shell consists of brick and mortar .. if we use a modulus of elasticity of the two??? also poisson ratio.. Also, I create new material from the material, but before or after scratching the panel, I cannot assign the material I defined from the static reinforced concrete tab... so I cannot replace the c20 reinforced concrete with the brick I defined, the material I defined does not appear in the tab???? If we compare the results with the pressure and slip safety of tdy??? !!!If anyone knows how to do it, please answer!!! How should all the numerical changes and modeling techniques be made in the program!!!! With health and well-being...
