Hello; I hope the attached file will work for you."dexana":3dehy0j0" said:I can't make the calculations of the ladder I put the picture of...I couldn't introduce the ladder to ide6..I would appreciate your help...
the problem doesn't go away even though I've highlighted the typical beams..."EngineerKUTLU":37iuk522" said:Hello. Typical beams that do not follow each other in your project have already been given in geometry control. You did not specify the typical beams in these floors. For some other floors, typical beams were determined. If you specify the typical beams just like in those floors, the situation will disappear! ...
Hello, In your project, D14-D13-D12-D19 ribs are not defined with each other, as well as account beams are not defined for floors other than D14. Also, although two account beams are defined in D8 slab, one account beam is defined in neighboring floors. If the rib teeth and calculation beams are defined as in the attached project, they do not give a warning in the geometry control. Note: The information given about the rib beams in the geometry control is a warning. If the rib calculation beams are to be applied as designed, these warnings may be ignored. Good work"coskun3561":2zs0zcof" said:greetings, on my rib-beam slab, it gives typical beam error in geometric check... I searched the forum. You generally cited the discontinuity of typical beams as the cause of this problem, but I tried to make it as continuous as possible, keep giving this error I would appreciate it if you could help.
Hello, in ideCAD I don't remember a message saying it's not defined for beam. We can help if you explain the program's "blocking" status of beam. You can attach a screenshot of the program's message or the project itself to your message"dexana":35qgsh1m" said:I have a little problem I want to make lemon beams(15/50) around the balcony perimeters but it keeps me saying that ide is not defined...what can I do?
