Hello, 1-Distance measurement When the command is used, you will see a dialog where you can select the unit. Here you can select the unit of measurement. Here, cm can be selected. 2-The layout design is a drawing window that is used to collect drawings in different scales together and to get direct output from the program. If you want to get drawings from autocad, you can use the existing drawings in the application and detail drawing windows. Thus, the pen thicknesses used in the drawing are also transferred to autucad. (ctb file created when dwg is exported) Good work"gripin":2aobak5w" said:thanks a lot for the answer. I did what you said, but two more problems occurred. 1- Although I set the layout size and drawings in cm in the layout settings, when I select the length measurement on the left tab and make the measurement, the result is in m 2- (probably due to the 1st reason) When I transfer the layout to autocad, the drawings are very large and only one tenth of the drawing is visible. That is, it is output in m in autocad. It's been a week since I started the idea, so I'm new, I would appreciate it if you could answer them.
Hello, your e-mail sent to destek@ideyapi.com.tr has been answered. If you send your problem via e-mail, you do not need to write to the forum. Good work"Umut AYDIN":2kedupwc" said:I EMAILED A PROBLEM REGARDING CONSOLE FLOORINGS destek@ideyapi.com.tr IF YOU CAN HELP ME GET EASY
"Umut AYDIN":nlxjhjim" said:sometimes WHEN I OPEN AN EXISTING PROJECT, IT GIVES ENCOUNTERED AN IMPROPER ARGUMENT ERROR I SAY OK BUT DO YOU HAVE ANY PROBLEMS? If you do not encounter the message above when opening your non-project files, the problem is a Turkish character problem.To solve the problem, edit the regional and foreign settings of Windows to Turkey and Turkish.You do not have permission to view link Log in or register now.
Hello, has been answered.In cases where you send your problem via e-mail, you do not need to write to the forum separately."Umut AYDIN":19shtqa1" said:GOOD EVENING, I MAIL A PROBLEM ABOUT A2-A3 IRRORITY WITH THE PROJECT. I WOULD LIKE TO HELP.
Hello, I am writing because you wrote a message to the questions section about the use of ideCAD Static 6: I think you know that you can switch to version 7 for free."fırat construction":7wq4xxtb" said:hello; when I export to autocad, the pen thickness is distorted. Which font should I choose when exporting so that the pen thickness does not deteriorate? Or how can I solve this problem? I would appreciate your help.
