Hello, In the project, the beams on the basement floor are 6 and the beams on the f axis are given an elevation of 38 cm. However, the columns to which these beams are attached are not given an elevation. The same columns should be shortened by 38 cm denim on the ground floor."dexana":2ezs71k5" said:hi, the ln value used when making column break security is higher than it should be in my project. Some columns have values like 6.06 while it should be 3.23 in my report... I am sending the project as an e-mail because its size is large.. I would appreciate it if you're interested...thanks
In the structure tree, the first behavior spectrum function (DSF1) appears as Z2. When you do Z3, you will see that it is Z3 in the calculation results."Umut AYDIN":3d64um62" said:file is available in the attachment. when I get the report it shows as z2. good work.
5 different behavior spectrums have been defined in the project as the admin stated. and the ground class was defined as Z3."Umut AYDIN":32kj7dbw" said:behavior spectrum functions don't have the little + sign you mentioned next to them, so they don't exist. I am sending the same project again
