Questions about using ideCAD Architecture 6
After I bought ide 6 and started using it, I started having problems. I had no problems with 5.511. There is a new problem for a few days. For example, when I want to open another floor plan or 2d drawing window, the screen freezes and does not recover without closing the project. Every time I go to autosave and get the final version of the project It is not very final, so I have to redraw the things I have drawn over and over again.
I'm using win7 64 bit, I'm getting the attached error when I'm taking the build quantities, what can I do, thanks..
I started having problems after I bought
"erturan":1quq5m41" said:
ide 6 and started using it. I had no problems with 5.511. There is a new problem for a few days. For example, when I want to open another floor plan or 2d drawing window, the screen freezes without closing the project. it doesn't get better. I have to go to autosave and get the final version of the project every time.
After I bought
"erturan":2nds8893" said:
ide 6 and started using it, I started having problems. I had no problems with 5.511. There is a new problem for a few days. For example, when I want to open another floor plan or 2d drawing window, the screen freezes without closing the project it doesn't get better. I have to go to autosave and get the final version of the project every time. /quote] Can you add a project you are having the problem with to the message or you can send it via e-mail to [email protected].
"mimsta":1nhgx2bz" said:
I'm using win7 64 bit, I get the attached error while taking the building footage, what can I do, thanks..
You can check whether the export.mdb file in the database folder under the program folder is read-only If so, cancel the read only status and try again...
I made Hakan Şahin's suggestion to update the video card driver to fix the program crashes in xp, but the result did not change, his other suggestion was to disable the 3D drawing mode and show 3D primitive objects buttons in the general settings, the program crashes ended for now, I hope it continues like this, thanks for the suggestions... I haven't implemented the suggestion about taking footage in win 7 yet, I will try it as soon as possible... thanks...
"gokalp":2618eqh8" said:
other suggestion disabled the 3D drawing mode and the Show 3D primitive objects buttons in the general settings and the program crashes for now
Is your graphics card an "Onboard" card? What is the brand and model?
"HakanŞahin":tuxa4t39" said:
"gokalp":tuxa4t39" said:
other suggestion is to disable the 3D drawing mode and show 3D primitive objects buttons in the general settings and the program crashes for now
Your graphics card is "Onboard" - is it an "integrated" card? What is the make and model of your video card?
[ NVIDIA GeForce 9600 GS ] Display Adapter Specifications: Device Description NVIDIA GeForce 9600 GS Adapter Array GeForce 9600 GS BIOS Version Version 62.94.20.0.4 Chip Type GeForce 9600 GS DAC Type Integrated RAMDAC Driver Date 26.06.2009 Driver Version 8.15.11.8627 - nVIDIA ForceWare 186.27 Driver Provider NVIDIA Memory Size 768 MB I listed my video card information on win7 64 bit computer above, crashes in idecad 6.0101v. were resolved after making changes in general settings as above, but ; Quantities cannot be taken in win 7 (32 and 64 bits) I first removed the crystal reports, I tried to download and install from the link you provided, but it gives an error and does not install, I think there was no change. Today a new problem came up, after my project worked in win 7, I tried to open it in xp. I tried, it doesn't open and the following message comes up: encountered an improper argument...
"gokalp":ik3eo9lu" said:
[ NVIDIA GeForce 9600 GS ] win7 .... I listed the information of my video card on a 64 bit computer above, the crashes in idecad 6.0101v. were resolved after changing the general settings as above, but ; win 7 Quantities cannot be obtained (32 and 64 bits) I first removed the crystal reports, I tried to download and install them from the link you provided, but it gives an error, I guess, there was no change. Today, a new problem appeared. After my project worked in win 7, I tried to open it in xp and the following text is coming: encountered an improper argument...
We also have NVIDIA GeForce 9600 GT and 64 bit windows 7... Call me at a convenient time for you, let's examine your question together through remote access (with teamviewer) and try to solve it...
We also have a system NVIDIA GeForce 9600 GT and 64 bit windows 7... I don't encounter any problems. (I'm working on the options in the general settings as well) As I wrote before, call me at a time convenient for you, with the remote access channel (with teamviewer) Let's examine and try to solve it...[/quote] Mr. Hakan, I'm using xp right now, I have a project with a size of 313 mb and xp does not open, the 150 mb previous record of the same project is opened, I cannot open it with its final version and the warning message I wrote in my previous message comes up. .thanks for your interest...
I have a project with a size of 313 mb and xp does not open, I tried it on 2 computers with xp installed at work, I get the same error message, the previous record of the same project of 150 mb is opened, I cannot open it with the final version and 'encountered an improper argument' appears... is it out of memory? what is the problem! I am waiting for an urgent solution, thanks for your interest...
Hi again, try setting the virtual memory to 4096 MB. (from my computer, right click properties, advanced tab). In the meantime, if you send us your project, we can see if it is opened and we can examine the problem. Put the project in a place where we can download it or write it on a cd and send it by cargo...
Hello, Your project opened without any problems on one of the two computers with xp in our office, it did not open on the other XP with lower memory. It opened without any problems on our computers with Vista and Windows 7. The size of one of the logo you used in the project is 38 mb. You used 8 of these logos in the project. Therefore, the size of your project has increased a lot (300 Mb). However, the resolution of the log you are using is 3851x3321, which is a very large value. We recommend that you reduce the resolutions of the logo to a reasonable size and include it in your project. After the logos were deleted from the project, the size of the project decreased to 64 Mb. When you use a logo with the appropriate resolution, the size of your project will not grow much and your project will run smoothly. I sent you back the project we modified by email (6 MB in rar version). You will be able to open the project on your xp computer. After you reduce the logos to the appropriate size, you can add them back to your project. Good work...
Thank you Hakan Şahin, I opened the project file you sent in xp, no problem, I learned that you should pay attention to the resolution ratios of the logos, by the way, we have confirmed that windows 7 is an operating system that should be preferred over xp...
CREATION OF COMBINED MATERIALS ON WALLS WE CANNOT CHANGE THE THICKNESSES OF THE COMBINED MATERIALS UNDER THE WALL KPMUTU. IS IT POSSIBLE TO CHANGE? OR HOW CAN I CREATE NEW COMPOSITE MATERIAL? THANKS
Re: CREATING COMPONENT MATERIAL ON WALLS Hello, you can change the thickness of the material you want from the drop-down list or define a new one by clicking Settings/Combined Materials. Good luck with...
___________I asked before, but I guess it was not seen...!!!__ Dear admin and my related friends. When using the new add block and layout block auxiliary commands with version 5, the objects that were previously in the unique layer are automatically converted to the standard layer. For example, while you can open and close objects consisting of a few lines in the line layer, it turns into a standard layer when you make a block or turn it into a layout block. Is there any way to fix this situation? If not, I request that this detail be corrected or added optionally in the newly prepared version. Thank you for your interest.
Hello, dear, it gives the error in the picture below in the related attachment in the demo version of idemimar 6.2004 Even though I open a new drawing screen and save the file as empty, it saves the file size over 200mb and takes a long time, and when I try to close it, it gives the error in the picture above. When I create a simple building and save it, it takes up too much space and the recording time is very long. To fix this problem, I opened the program by resetting it with ctrl+shift keys, I tried reinstalling the existing demo program on it. I request your information about why this problem occurs. Thanks in advance for your interest.
