kubravayni1992
Re: Ask for opinions on using ideCAD Architecture 7 and 8 take it easy guys, I just started using idecadi.. I can't create a roof, can you help?
If you call our Bursa office, we can connect to your computer with remote access and look at the problem together."professional":3b6zc1gl" said:Greetings, I have a minor problem in 7.22 architecture and statics for a few months, I would appreciate it if you could help. As soon as I click the door window command while creating the plans, the program stops working. However, this only happens when the perspective window opens on the right side of the drawing screen. There is no problem when the 3d perspective window is covered. That's it, if you can help me out. I've uninstalled and reinstalled the programs a couple of times, even from different setups. and I installed different current and old drivers for 2 of my 3 video cards. My video card is gigabay rx580 4 gb gaming model. There was no such problem when I had an old 750 ti video card in my system. Other system components and system features. - windows 10 pro version 10.0 .10586 asus z170a motherboard. 6700 intel processor corshair 16GB (2x8GB) 2400 mhz 750 watt gold certified psu Pc is working very stable. I have not had a problem with any application. Thanks again.
Hello, In Settings menu, 'object visibility on floors' The 'show active floor' option must be turned off for static objects in the command. You can model the chimney with walls. If you want to open the spaces in the floor and space, you can use the floor / space space commands, you can use the 2D drawing tools for details on the plan. Take it easy, good work.Is there a command how can I turn off the projection of beams and also add fire chimneys?
Sir, in the same situation, column lengths will be fixed. One of the beams is at -150 cm elevation. The other two are connected to this beam inclined from +0 to -150. (I'm taking care of the beams). But when you give that floor a -150 level this time the back part is lifted.Is it possible to give only -150 jeans to the other side of the floor that is fixed on one side?"Zeynep Aladağ":319igx34" said:You can bevel your tiles with the "Bevel Objects" command from the tiling toolbar. Click on the bevel[/b] icon - Select the tile you want to bevel and click the right mouse button. - Select/not select objects around the tile from the dialog that appears - Draw your direction to determine the direction of the slope. - Slope options
