HakanŞahin
Administrator
Re: ideCAD 6.01 BETA2 Update.. Try it, give your opinion...
Hello Mr. İbrahim, If you want to see the screenshot you have set in a new project, you should set that setting as "template project" you should open the new project with that template project. or you should load a project that you set the screenshot as default and select the "start using the last settings" option when opening a new project. These processes work smoothly in the program and do not require any editing in the program. Good work"saridurmus":3oepx95g" said:In 6.10 beta2, enter the image\image configuration, for example, by dividing it vertically into two, and registering it. When we go to open a new project, the program's defacult comes, not ours. .... only the screenshot will be corrected in the next version anyway?
