Arzu Dural Gök
Hello, you can upload and link to hotfile or similar site.
			There is a report file in the link you added. I couldn't see a general problem in the report file. Raft flooring reinforcement Rearranging the axis of the axles by determining the places where the moment is less can provide a more economical solution.If you attach the project file, the data entry can be examined in more detail."coskun3561":6l6uoiae" said:http://hotfile.com/dl/122638660/7e89f10/katek1.rar.html
In the project you added, there is a In your project, the lower moments on the calculation axis no. 1 forced the system a bit. Therefore, the fi16/13 reinforcement is thrown. If the reinforcement axes and working distances are arranged as in the example project, the fi16/13 reinforcement in the X direction is thrown only at the distance arranged in the project, instead of the entire span. It also provides reinforcement economy"coskun3561":2p7tdadm" said:wrong, I didn't quite understand. Now I am sending the middle part of the analysis. The version before the edits. The part I was wondering about is the basic equipment part, the other parts of the project are a bit messy when I send this.You do not have permission to view link Log in or register now.
Hello, It is a drawing technique used to prevent reinforcements from overlapping in expansions. With the ] command, you can move it to a suitable place and delete the line."coskun3561":39nwiazl" said:greetings, what is the meaning of the dashed line in beam expansions?
Thank you very much for taking the time to reply..it was very enlightening..."HakanŞahin":14by266n" said:Hi, For item 1: If checked, eccentricity : ex= | ym-yr | + 0.05 * By ey= | xm-xr | + 0.05 * If Bx is not marked, the eccentricity is taken into account as ex= 0.05 * By ey= 0.05 * Bx Xm, Ym = Abssi and ordinate of the center of mass Xr, Yr = Abssi and ordinate of the center of rigidity Bx = Horizontal building dimension By = Vertical building dimension to TDY Ex= 0.05 * By and ey= 0.05 * Bx is sufficient. If you want to take into account the excessive eccentricity during the effect of earthquake effects on the structure, you can mark it. If item 2 is checked, cantilever beams are also included in the column-beam shear safety You may not tick this option as it is not clear in the regulation. Article 3 relevant to the shell analysis. If we talk specifically for slabs, you do not have to mark it because slabs are equipped with bending moment. In short, it has no effect on the overall analysis. In 3D frame view , truncation for shell results and if you want to examine the normal force effects, you mark it. 4. clause should be applied for floors that fall into groups C and D according to TDY. Other than that, you don't have to mark it.
Hello, This is within our knowledge. You can delete the K05-K06 beam expansion drawn for the second time and continue with the project."dexana":2rp9q6m5" said:HELLO, I HAVE A PROBLEM WITH THE BEAM EXTENSIONS. IN THE PROJECT I ADDED, THE 5TH AND 6TH BEAMS ARE DOING EXTENSIONS 2 TIMES. THE FIRST HAS BEEN SHOWED WITH THE NUMBER 4 AND THEY CONTINUE TO RECEIVE 6 WHY IT IS THE SAME, WHY IT HAPPENS? I WOULD LIKE TO HELP YOU...
It would be more appropriate to use the wink spring method for beam foundations. I CAN'T UNDERSTAND I HAVE STRESS[/quote] In your project, in the raft laying parameters, the minimum prime draw price and the minimum other shrinkage rate are 0.0025. See TS 500 e these values can be entered such that 0.0020 and the total odds are 0.0035. Arrangement of reinforcement ratios in this way provides reinforcement economy in foundations operating at minimum price. In addition, if the foundation works at a minimum, reducing the thickness of the foundation can also provide economy. (For example, in this project, if the raft thickness is 70 cm and the min prime shrinkage and minimum other pursantage is 0.0020, the reinforcement becomes fi16/15.)ANOTHER TECHNICAL TOPIC IS VERY NEW BECAUSE I AM AN ENGINEER, I WOULD LIKE TO HELP YOU WITH IT, IS IT A SUITABLE SOLUTION TO USE WINKS ON BRAIDED FOUNDATIONS?
We have added the situation to our detection list. Thank you for your attention."Oznb":1ekt8ocp" said:idestatic V 6.54 sets the layer of stirrup details as standard when printing details inside column application plans .does not show as reinforcement line
Hello, the problem with the beams is due to the lack of stirrups. If the stirrup diameter of 10 is selected in the reinforcement selection dialog and analysis is made, the problem is solved."coskun3561":1ymptmmf" said:greetings, I have a problem with the beams in the middle part of the structure in the link, can I get your suggestions?
Hi, Uncheck the Auto-name split objects line in the beam assistant toolbar when connecting beams to curtains. In this case, the split panels will not be named differently. However, wrong panel/beam intersection message, It may be given because your beams are not attached to the panels at the right place. If you add your project, we will review it. Good work"dexana":3qmpxak3" said:hello, I have a problem with curtains. When beams are stuck to the curtain from different points, it divides the curtain and gives an error by naming it differently because it is the wrong panel/beam combination...
