In the attached villa project, we modeled the D36 slab on the 1st Floor ceiling with the "slab edge" tool to work between the K8 beam, SG3,SG4,SH3 and SH4 columns. A detached part of the roof will sit on this slab. The L-shaped slab is also connected to the K15 beam and SF4 column on the right. In this state, the D36 slab is solved as a cantilever slab in the program. How can we define this D36 slab as "a beamless slab resting on columns SH3 and SH4" among the elements mentioned above?[/quote ] Hi, Reinforcement type is automatically selected as "console reinforcement" rather than slabs are resolved as cantilever. Change the type of calculation axes defined in both directions as top flat+bottom flat reinforcement type with the reinforced concrete calculation axis edit command. However, there are two more issues here: 1. Plate During the analysis, the slab was defined as fully attached to the K8 beam depending on the option "this beam bears the cantilever floor" and that support slab It's like carrying it completely. If you do not want it to be fully attached to the K8 beam, disable the "This beam bears the cantilever slab" option in the K8 beam properties. Similarly, if you want, you can define the slab with full attachment to SH3 and SH4 columns. To make the slab fully retained on the column, check the "This column bears the console slab" option in the Column properties. 2. The slab is analyzed according to vertical loads, and it is accepted as an element of infinite rigidity in the floor plane. Therefore, the flooring is designed for vertical loads only. However, SH3 and SH4 columns connected to the floor will also be connected to the floor diaphragm. In order to take into account the earthquake effects for the D36 beamless slab, it may be appropriate to analyze it with another model, as well as a partial beam-slab system with hidden beams.
				"Görkem2007":35djkbzf" said:
			We also want to make slab punching calculations around SH3 and SH4 columns in D36 slab and get the report. How can we do these?
 You can make a punching verification for SH3 and SH4 columns by using the column header command and get the report If you do not want to make a "table" for stapling, enter the height and table height values as zero in the column heading settings.
			We also need to write the Tx, Ty and Tb period values of the structure on a form before submitting the project for approval. Where can we see these values in ideCAD Static 6.5?
 The periods of the structure are printed in the dynamic analysis report according to the modes. The direction in which the mode is active is also indicated in parentheses. 1. MOD (Rz), 2.MOD(Ux), 2.MOD(Uy) etc. Good work
