Levent Özpak
Active Member
Hi, beam panel connection and rigid arms created in -b1.cde- file are more accurate. We added the situation in the beam-panel connection in the -a1.cde- project to our notes. Good work
"tavekkul":2s68xcrs" said:When I analyze the attached project, all foundations seem to be recovering, but when I receive the report, I encounter the error that the st18 soil exceeds the safety stress. the ground tension is greater than 15 t/m2 (16.02 t/m2). Therefore, the ground tension is actually exceeded, but the program catches it only when receiving a report. If you give the name of the part under the P03 foundation different from the other parts, you can observe the situation. you can take action on the continuous basis model by value... Thanks for your report, keep up the good work...
There is a little negative stress at the bottom of the foundation at a point affected by the curtain. this is not important. disable the negative tension control You can opt out."coskun3561":3lm52sqm" said:I will review the project again, thank you for your interest. Take it easy, good work.
Total curtain height is twice the curtain length If the wall end zone is not exceeded, that is, if the critical wall height is not exceeded, there is no need to create a wall end zone as per the regulation (Regulation article 3.6.2.2.1) However, if it is still desired to create a wall end zone, the length of the Head zone can be defined by marking the user defined line in the reinforcements tab of the Wall Properties.Note: If HW/ If the end region is not created despite the condition Lw>2, then there may be a continuity problem on the curtains."Oznb":umomk188" said:does not create a title on 2 curtains with a curtain length of 625 cm Can you help ?
Hello In your project, there is no slab edge parallel to the E axis at the top, you can define the raft tiling by drawing a static slab edge passing a few cm above the E axis. You can create a space with the slab gap command."coskun3561":165aaz2i" said:hello, I need to make a space on the raft foundation for the elevator pit. I tried to make a space on the raft foundation by throwing the foundation beam around it all the time. I am attaching the project.
I can remove the slab edge on the E axis. I drew the floor space from the continuous foundations you defined, I emptied the continuous foundations and defined another raft foundation at low elevation. You can adjust the elevations, continuous foundation and raft foundation thicknesses according to your project."coskun3561":3svvkvqf" said:I stated that I do not want to do it with slab gap. I can do it that way anyway. My aim is to close the edges of the gap with beams. There should be a slab edge on the E axis, it may have been deleted.
