coskun3561
i am working in demo version
If you hold down the shift key on the keyboard, click on an empty area and select a rectangle so that it touches the relevant lines, you can select the lines."coskun3561":2aw09pf3" said:problem, I couldn't reach those lines anyway, thanks
You can download the latest demo version from our website."coskun3561":2aw09pf3" said:by the way, I couldn't open the one you sent me. gives version error
Hi, It is normal for the curtain to split into two. but the names of the two parts of the curtain must be the same. For this, you need to deactivate the -auto-name split object- command in the beam assistant toolbar when entering the beam. To combine panel parts with different names into one panel, select one of the parts. Give the name of the panel the same as the other panel in the panel settings with the object properties command. Good workI'm a new idecad user, I was dealing with a project in idecad, but there is a problem, I don't understand why, when a beam is inserted between the curtain, it is seen in the appendix
The height or width of the beam can be increased. If the deflection of the beam is close to the limit value, the compression reinforcement can be increased. The direction of the ribs can be changed.Etc."armedesign":2oyhf4bl" said:Hello, I just started learning idecadi, I solved the project we made by hand in the concrete project class with idecad, but there was a 7.86 meter span in the project. We are asked to solve other floors with ribs as normal. When I solve it as ribbed flooring, I encounter the problem of exceeding the deflection limit. How can I overcome this problem?
Hello Probably, beam K56 is not connected to panel P11. Activate the line -intersections- in the auxiliary toolbar while drawing the beam. If you cannot solve the problem, add your project." Siyahkale":23or6c71" said:hello add, as you can see, it shows the same flooring for 2 different rooms, but it had to show the floors separately, why?
