HakanŞahin
Administrator
Re: GALLERY MODELING...???? The gallery can be modeled with panels as a shell...
zero) should be taken. B1 irregularity appears because it is not taken..."Admin":33eisxgg" said:Hi; The program does not seem to take into account the wall areas on some floors due to the earthquake code clause 2.3.2.3. The ground floor Ak values(27.01-33.34) are greater than the 1st floor(26.77-33.10) , There is a similar situation between the 1st floor and the 2nd floor, but this situation may not be understood from the report because 2 digits are printed after the comma in the report. If you can send your project, let's examine it in more detail...
Hello; Some adjustments have been made in retrofit reports to make it easier to follow. Damage coefficient, limit values, damage status and damage cause will be given in order as arranged in damage status reports. The performance evaluation of the columns is evaluated according to the ratio of shear force, the number of informational elements is given in the reports, and the shear force ratios of the elements that do not provide in the prepared report format will be given."suatyy":1ydatafw" said:Dear Sir, I am comparing performance analyzes due to my thesis. I would like to convey my findings about Idestatic performance analysis so far. I wrote to the technical support department, but in a short time I am writing to the forum with the thought that there may be someone else who may be interested or there may be friends who have worked on this subject, since I did not receive an answer. The impact moments found in the earthquake analysis made with 1-R=1 are higher than other programs. The element capacity figures are also contradictory to other programs. 1-Earthquake load in the performance analysis While it is necessary to remove the frame elements in the related loading direction, the secondary beams are also included in the percentage calculation of the damaged elements in the Idestat. 2-E/K ratio is given in the reports, but since the r limit leather, which is the basis for the evaluation, is not given, it cannot be understood why the element has collapsed if it has not been cut. in the performance analysis report (1st floor S06) S Given r=3.96 in the 106 +X direction, the element is not brittle, the relative displacement is still within limits, but still collapses. It can be interpreted better if r limit values are given. 3- Columns should not be evaluated by the number of elements that do not provide performance evaluation, but by the ratio of the amount of shear received by the elements that do not provide this to the total amount of floor shear. However, I could not find any information about shear force ratios in the last evaluation table and reports of idestatic. Greetings Suat
There may be a problem with the intersections. If you add the data, we will examine it..."coskun3561":1u5t6b85" said:what is this line? how can I delete it?
