Questions about using ideCAD Architecture 6
PLUSTER LINE In the 5.51 version, the scan on the cross-section was plastering all over the scan at 2cm offset, does it not do this in the 6.002 version, with respect?
Re: PLASTER LINE Hello Mr. Ahmet, I could not fully understand your question. We'll try to help if you ask for a bit more detail or support with a screenshot.
"ahmet özer":14k544xh" said:
In the 5.51 version, the scan on the cross-section was plastering all over the scan at 2cm offset, does it not do this in the 6.002 version, my respects
hello, I wonder if it is possible to rotate the default working plane other than XY, zy, zx ... in the plane objects such as column walls or rotate horizontally, in order to be able to work in 3D more comfortably.
Hello, it is possible to define different working planes in the program, but it is not possible to angle the wall or column in these planes in the sense you mentioned at the moment. You can angle the columns with the tilt parameter in the column settings. The wall object cannot be drawn at an angle in the architectural program. You can get the same model as the roof surface. Since the window that takes the roof surface slope will also settle, it will look like a wall in 3 dimensions. In addition, you can now draw an angled surface with the horizontal on the curtain wall element in 6 versions. You can also use this object instead of the wall.
In ideCAD Render, all objects can be viewed as different' possible to rotate.
hello, first of all, I would like to thank you for your innovations and updates. With each new version and additional versions, new quest requests and problems arise. I know the development of this program, which I have been using for 12 years, over the years. Even though all requests are answered, requests will always come out again. The person who used the program in the past years could easily learn and use it. nowadays it takes quite a while for a new user to fully learn this vast content. This situation was facilitated by idecadin's video lectures and this forum. Previously, many features were done by trial and error method thanks to the help files. I wish you continued success and success in your work. - (error1) The wall in the attached picture or the objects with nodal points such as columns, beams and curtains cannot be moved up and down as much as 20 cm in the picture. because the nodal point is not transported as much as the nodal point distances in the vertical direction. This distance does not change no matter what. -When using the make block and layout block auxiliary commands, the objects that were previously in a unique layer are automatically converted to the standard layer. For example, while you can open and close objects consisting of a few lines in the line layer, it turns into a standard layer when you make a block or a layout block. I request that this detail be corrected or added optionally in the newly prepared version. -The dimensions of the libraries change after they are placed. when it is re-edited, it becomes fractional. -circular wall, curvilinear wall, diameter, angle and direction change when a wall drawn with a continuous arc wall is taken symmetry - I can't capture at intersections of primitive objects. We want the capture support commands to be detailed and active for all objects, as in other cad programs, while there are in older versions -We should be able to export layouts as PDF with PDF support. - Easy dimensioning can be given to interiors with automatic dimensioning. - The feature of automatic axis passing through the belts should be added - The plaster feature should be added to the curtains and the elements cut in the sections in architecture. In previous versions, plaster was created by scanning and offsetting the sections we wanted in the cross section. now the scan itself is offset. I couldn't figure out what it does, but the feature has changed. As in ide architect 2.0, floor and 2b windows should be opened side by side on the screen. - It would be nice to be able to make command-based entries from the keyboard. It should be possible to enter by typing on the command line, not a shortcut. -Change of texts should be added to the object properties. your change text command is a superfluous command. - Ability to enter L value directly: Using the numerical keyboard by showing the direction directly without pressing the L key (a kind of fixing the L) according to any fixed point or tracked tracking point will provide us with the comfort and speed of Autocad. So "wall"-"direction"-" L"-"200"-"direction"-"L"-"400" etc. instead of "wall"-"200-400-600" etc by setting the direction with the mouse. in the form. (see Autocad)
I am idecad 6.0055 user. When I uploaded 6.2007, the section and view took up to 15 minutes. Anyone know what could be the reason? Could it be due to ram? Or is it due to the operating system? URGENT EMERGENCY EMERGENCY... PROJECTS UNLAWFUL
"aydinaydin":1tommim8" said:
I'm a user of idecad 6.0055. When I installed 6.2007, it took up to 15 minutes to get the section and view. Does anyone know what could be the reason? Could it be caused by ram or is it due to the operating system? URGENT... PROJECTS UNFIT :D
Hello, there is no change in the section after 6.055 on 6.2007. Could you add your project?
Hi, Ever since I upgraded to version 6.2007, I've been dealing with problems with the program. Which one shall I count ... Updating as I know it is an upgrade to a new and better version. We couldn't see a stable version among many updates you made this year, (except 6.2006), please don't bother us by updating beta versions like this...
Hello Mr. Gökalp, why don't you try to state your problems in a concrete way? What kind of problems are you experiencing? As far as I know, you have not contacted our technical service and reported any problems. In the 6.2007 version, we brought you 664 new library objects, from interior to landscape, from garden furniture to wet area elements. Our updates will continue with new libraries and new possibilities. Please report the problems you experienced in 6.2006, the situations you experienced in 6.2007, and the sample projects, item by item, by phone or here as you wish, so that we can correct any errors caused by the program. If there are errors related to your usage, you correct them. Best regards
[Hello Mr. Gökalp, why don't you try to state your problems concretely? What kind of problems are you experiencing? As far as I know, you have not contacted our technical service and reported any problems. In the 6.2007 version, we brought you 664 new library objects, from interior to landscape, from garden furniture to wet area elements. Our updates will continue with new libraries and new possibilities. Please report the problems you experienced in 6.2006, the situations you experienced in 6.2007, and the sample projects, item by item, by phone or here as you wish, so that we can correct any errors caused by the program. If there are errors due to your usage, correct them.] Ms. Arzu, I think the 6.2007 version consists of adding library objects, so the installation file of the program has increased from 200 mb to 500 mb, this program does not require the computer to crash, autocad 2009 2 gb, revit 2009 2-2.5 gb It is installed from the setup file, but neither autocad nor revit works easily even on a 1 gb ram computer, but I think 8 gb ram is required for the new version ide, because I saw that it stuttered even on a pc with 4 gb ram. One of the reasons for the contraction is to use library objects intensively, for example, in a project, I put 50-60 tables and chairs on the floor plan, the program was paralyzed...
Mr. Gökalp, first of all, send the project you are experiencing the problems you mentioned to [email protected] and we will examine it. Messages reported to the forum as "which one should I count" are not getting us anywhere. In order to produce a solution, we must first see the problem ourselves and be able to create it on our own computers. Have you tried working on a project that contains the same density and level of detail as library objects with other programs? The libraries have both detailed libraries for rendering (we kept the library detail levels high to get high quality indoor rendering) and less detailed libraries for general work. If you use 50-60 such detailed libraries on each floor in your normal project, the slowdown you mentioned is normal due to the nature of the process. Use libraries with less than 3D detail for floor plans. When you are going to render, just add detailed libraries to the space you will take. If you want to use the detailed libraries in the plan, we can add an option to "use only the plan view of this library" in the next versions. We expect you to describe the other problems you mentioned in detail as soon as possible.
"KUBA2009":3k2n82qi" said:
- (error1) in the attached picture, objects with joint points such as the wall or column beam curtain cannot be moved up and down as much as the joint points, as much as 20 cm in the picture, because there are as many nodes in the vertical direction as the joint point distances. point is not moved. This distance does not change.
The program does not allow this because a zero height wall will be formed on the vertical part. You can create a similar geometry by placing a 20x20 column in the intersection area.
- When using the make block and layout block auxiliary commands, objects that were previously in a unique layer are automatically converted to the standard layer. For example, while you could close and open objects consisting of a few lines in the line layer before, it turns into a standard layer when you make a block or turn it into a layout block. In the newly prepared version, I request that this detail be corrected or added selectively.
Layout block command is designed as the last operation. In other words, you have completed your project, now you will place it on paper for printing and send it to the printer, your work will be finished. In this context, you should have no more work with layers. It can be added for the regular block, but we do not intend to add the feature you want to the layout block.
- I can't capture at intersections of primitive objects. While in older versions, we now want the removed capture support commands to be active for all objects in detail as in other cad programs
with advanced snap command in 2 dimensions You can catch the intersections (holding the ctrl key) A node is already formed at the intersections of 3D wall/wall etc.
-We should be able to export the layouts as PDF with PDF support.
Made for the next free update (version 6.5). (Both as 2D and 3D pdf export).
- easy dimensioning can be given to interiors with automatic dimensioning.
You need to elaborate this request a little more.
- automatic axle passing through belts feature should be added [/ quote] Isn't it more practical to define your axles first? It didn't seem like a feature that would make the architect's job much easier...
- plaster feature should be added to the curtains and the elements cut in the sections in architecture, elements such as columns, beams, and tiled walls should be added in the sections, with or without plaster. Plaster was created by scanning and offsetting the regions in the section. Now, the scan itself is offset. I couldn't figure out what it does, but the feature has changed.
As we did for rendering in the previous version, the section is now being redesigned to meet the needs that have emerged over the years... [quote ="KUBA2009":3k2n82qi"] - As in ide architect 2.0, floor and 2b windows should be opened side by side on the screen.
If you explain how you will follow a working system using this feature (like for editing a section?), we can develop a more purposeful feature.
-change text should be added to object properties. change text command is an unnecessary command.
Editing text itself does not fit this process as you can change the properties of more than one text with object properties command. Although Even if we don't respond sometimes, we read and evaluate every message posted on the forum, don't worry.
Of course you are reading, but even though it has been 30 days since I sent mskj, when I replied to 2 people who msg me after me. I wrote a msg again, thank you for your interest, but if you give a short cvp, you will be more interested. It seems like such a useless forum when you can't come to cvp. but when you give cvp, mutual respect and value are felt. Of course, your job is difficult, but I am honored that the program and the people affiliated with the organization gain value along with myself. You also shed some light on some issues. ff. I will. You have shed light on the node point. when enlarging and reducing a completed project with a node point. I cannot assign a column to each node when they are close to each other. I want you to draw a wall or line in the form of a square 100cm by 100cm. scrolling it vertically or horizontally with the node. in other words, it is necessary to find such approaches one by one in a large project. circular wall, curvilinear wall, a wall drawn with a continuous arc wall, the diameter, angle and direction change when symmetry is taken. (I think you have seen these problems)) easy dimensioning can be given to the interiors with automatic dimensioning (that is, when the space is thrown, it is optional in architecture, as it does in static flooring, when desired. If the interior dimension is given as the interior dimension, it will be great when designing :) I want the floor and 2b windows to be opened side by side on the screen, as in ide architect 2.0, because while drawing the situation, project details, sectional facade, it is necessary to use copy-paste codes and constantly change the screen. If we can open it side by side, it would be very easy to copy it with the keyboard shortcut and paste it on the second click. In my opinion, it would be easier to use it by opening and enlarging it instead of switching between two different floors. this need becomes even more necessary in editing changes. It shouldn't be difficult to add a layer change to the layout block. You said ( Layout block command is designed as the last operation. So you have completed your project, now you will place it on the paper and send it to the printer for printing, you will be done. In this context, you should have no more work with layers. yes it's done but after a while I had to make changes in the layout, it just needed to be done by breaking it down without updating. For example, in architecture, I draw the stove chimney drawings with the line and circle command. And to create the plaster line for the chimney together with the wall, I transfer the floor plan to 2 dimensions here, after editing the plaster lines of the chimney and wall with the extend, trim, fillet commands. Then I make a layout block. Then I delete the drawing that I transferred to 2 dimensions in order to reduce the condensation in excess space, area and drawings. In the future, when I want to make arrangements, I cannot use layers on chimneys or any other part. Additionally, when we print out the drawings we have finished, the printout is taken. we can't find the idea in companies. or di When we transfer and give it to the related people as dwg-dxf for the drawing of projects such as mechanical installation, electrical static fire, for drawing of other projects, the projects given by us cannot be used because of the same layer problems. this causes us to waste our time. In addition, when trying to transfer to autocad and print out, it is necessary to make adjustments depending on the time regarding the thickness of the pencils. and, if any, I would like a fully completed architectural application project sample made by you to be added to the forum.
6.2007 version issues; Since 3D libraries are intense in my project, I decided to make object fragmentation and then make a block and use 2 dimensions, nothing changes. In other words, the computer contracts excessively. This is how I rotate, move, mirror, etc. It can be done with a lot of effort. (Same on 4gb memory), it takes too long to create vector drawing like 5 minutes,
Let me continue to exemplify the problems; I enter the thickness of the space (-) value so that the elevation of the space appears as the rough construction elevation in the quarters, after saving and exiting the project, when I open it again, I see that the (-) value changes to (+), so my space elevations are deteriorated...
Hello, Mr. Gökalp, as you can see in the picture below, you can print coarse and fine jeans at the same time by ticking the "write floor level" option in the jeans measurement settings. In a single measure, the program shows thin elevation. I think you have entered a minus value for the thickness to show one size and only rough jeans, but the thickness cannot be a value. To do this, you must use jeans. You should take the jeans down (as much as the thickness of the space). It is very logical and not a mistake for the program to make (-) the given value (+). From this it turns out that we have to prevent the entry of the thickness (-) value from the beginning, because it has led to misuse. In addition, we can take the request from your message that we have users who want to show a single level without showing coarse or thin elevation, and that this should be connected to an option such as show coarse elevation, show fine elevation in single display, and apply it in program updates. Regards,
"gokalp":3diwfp6m" said:
Let me continue to exemplify the problems; I enter the space thickness (-) value so that the space elevation appears as the rough construction elevation in the spaces, after saving and exiting the project, when I open it again, the (-) value returns to (+) , so I see that my local jeans are spoiled...
"gokalp":21rn8016" said:
One of the reasons for the contraction is to use library objects heavily, for example, in a project, I put 50-60 tables and chairs on the floor plan and the program was paralyzed...
Hello, in the Settings/General Settings dialog " You can turn off the "Activate 3D mode" and "Draw primitive objects in 3D" options. This will increase your performance in projects using high density libraries. Good work...
Hello friends, I want to ask how we can enter the following coordinates and a certain zoning diameter in the idecad. For example, I try with reference to the point (0,0), but an irrelevant parcel comes out. Thanks in advance for your help...
"volvoxx":14zp23lc" said:
Hi friends, I want to ask how we can enter a certain zoning diameter in idecad. I want to ask the following coordinates. For example, I try with reference to the point (0,0), but an irrelevant parcel appears. Thanks in advance for your help...
Hello, Your question is answered in ideCAd Architectural Help. Click Content line from Help Menu in the program. In Search Tab -To the keyword line to be found- -Diameter project contour Type - and click the List Topics button. Related topics will be listed below. When you select the topic, you can access the information given on the screen on the right. Good work
I also experience the muscle contraction that Gökalp Bey experienced. While we were happy that the program was small but comfortable to use without any contractions in the previous versions, it is sad to see this now. Also, you say that you have increased the details for interior renders, I use the render mostly in the parts related to exterior and landscape, there are 3D objects in the last version, now the error I get in the "Defining Scene" part of the render is "KD-tree Error". When I put a little more trees, it immediately gives this error in the rendering process. I am getting this error especially in grass&feather production (no matter how much I lower the grass density and quality, sometimes lowering the quality works). It gives the same error when I put a tree in the same way. and I constantly have to go back and delete trees and reduce the 3D objects I add. which is insufficient. The painful situation of deleting the work done is another dimension of the job. Of course, is it more appropriate to have the rendering processes done by the computer's processors or 3D graphics cards? Of course, the developer engineers will know this better, but as far as I know, the RAM timings and operating frequencies of 3D graphics cards are faster than PCRAMs. Many renderings occur simultaneously in operations in games. and it's not that hard. In the same way, while the ATI brand graphics card has contraction during the design, it works more comfortably on graphics cards with nVidia chipsets. I would be very grateful if you could enlighten me on these matters. Because I'm even considering buying a new PC for these processes.
