Hi, I would like to share a couple of issues... In order not to cause confusion in the above statement, "The mixed system was chosen, the R Coefficient is 6, but the ratio of the sum of the curtain shear forces to the total base shear force is 2/3' Isn't it necessary to write "less than ten"? In mixed systems, the highest value of the R coefficient is already 6. Isn't there a contradiction in this expression? Wouldn't it be correct to write directly: "The mixed system is selected, but the R coefficient is greater than 6."?[/quote ] According to the regulation, Ryp can be both 6 and 7, the R=7 check is valid if the ryp is written 7. The program accepts ryp=6 (an option was added in the 8th version) Therefore, R>6 is checked under all conditions. As a result, we can say that there is no need for the control you wrote 1. We can note and evaluate the issue
"proisa":qydda13f" said:
In such cases, the program does not give an error. "The mixed system has been chosen and the R coefficient is greater than Rnc + 1.5 alphas(Ryp - Rnc)." Don't you need a warning? Good work...
It is normal that the program does not give an error here, because the Rnc + 1.5 alfas(Ryp - Rnc) calculation is not a value found at the beginning, but a value found at the end. If the program checks this value and applies it automatically, the alphas will also change each time. For this reason, the user should evaluate the value that the program finds Rnç + 1.5 alphas (Ryp - Rnç) and use it in the calculation accordingly. Good work
