"illaga":3hi5o11w" said:
The file is attached Mr. Levent. Also, I had one more question. In systems with floor level, should we give our columns an upper level or connect them to the column on the upper floor?
*In addition to what Nedim Bey said, in the project, it is seen that the S35 column can be entered in the ground and mezzanine, but not in the basement on the floor. *In case the floor is given a positive level, it would be appropriate to give an upper level to the columns and beams attached to the floor. Vertical continuity should be provided by raising the relevant columns on an upper floor. Good work
