metinkacar
Re: Opinions and questions about the use of ideCAD Reinforced Concrete 8 Hakan, I sent an e-mail to destek@ideyapi.com.tr because the file is large. good work
Hello Mr. Ömer, Since the 1st subbasement has low elevation, it is considered together with the foundation pattern. Therefore, it is shown in the basic application. Can you add an example for 2, 4 and 5?"siromar":20d5ao2d" said:I wanted to share a few mistakes I noticed 1) Basin curtains with low elevations are not visible in the basement formwork plan 2) The dimensions of the main shear walls are printed incorrectly 3) When the wall loads are taken from Idemimari, the beam wall loads report is printed incorrectly 4) When I close and open the project, it becomes a serious problem that the scans go to other places or disappear 5) Select some columns or curtains and get column application When I say that, the program crashes and closes. Good work
