Opinions questions about the use of Reinforced Concrete Design
Re: Opinions about using ideCAD Reinforced Concrete 8 questions I made automatic naming on the ground floor. Some beam names on the basement floor are not visible. The name appears in the settings but does not overwrite it.
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions
"Oznb":xhlc8377" said:
I made automatic naming on the ground floor, some beam names on the basement floor are not visible in the settings, but it does not overwrite.
Problem I didn't see it, can you add a sample picture?
Re: Opinions about using ideCAD Reinforced Concrete 8 questions The font of the font was deleted .... it was fixed after changing the font ... thanks...
Re: Opinions and questions about using ideCAD Reinforced Concrete 8 When I want to import the attached dwg file, the program breaks.
Re: Opinions about using ideCAD Reinforced Concrete 8 questions A VERY SIMPLE QUESTION. WHY DON'T TWO BEAMS CONNECTED TO COLUMNS LARGER THAN 85 CM CONTINUOUS? REINFORCEMENTS FINISH IN THE COLUMN IT IS CONNECTED TO CONTINUOUSLY.. YOU CAN TRY IT
"teroysa":2qik7fo9" said:
A VERY SIMPLE QUESTION. WHY DO TWO BEAMS CONNECTED TO COLUMNS LARGER than 85 CM WHY DO NOT CONTINUOUSLY LOOK AT THE CONTINUOUS CONNITATIONS? YOU CAN TRY IT
Yes, this is neither V7 nor V8. The attached file contains both v8 and v7 drawings of the beams connected to the 90 cm column. As teroysa said, the beam is discontinuous in v8. Also, I add flooring to the ground floor in the file I sent It's ok, but when I add tiles to the upper floors, system cannot be resolved error. Could you please check it out. Also, the forum does not accept *.ide8 file extension. That's why I made a cde.
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions When idecad is dwg in 8 centimeters, the scala of the axle lines remains in meters.
"Oznb":3ebouzfb" said:
When idecad is dwg as 8 centimeters, the scala of the axle lines remains in meters.
Hello, We will report the situation you mentioned to our notes. Thank you for your feedback.
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions hello, after I completed the calculation part of the project I was working on, I started taking the drawings for the detail drawings. What could be the reason why the program gives an error and forces it to close while doing the ladder analysis and getting the details?
"özdemirözer38":w4xfx18x" said:
hello, after I completed the calculation part of the project I was doing, I started to receive the drawings for the detail drawings. The program gives an error when doing the ladder analysis and getting the details. What could be the reason for forcing it to close?
Hello, Can you add your project?
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions Stair drawings can be taken after the stair support and reinforcement axes are defined in Ver 8.029 in the project you added.
Re: Opinions and questions about using ideCAD Reinforced Concrete 8 I installed the current program I have on another computer, it gave the same error, I think the problem is caused by the program lock. I also tried the account axis and support situations as you said, it still doesn't work.
"özdemirözer38":32f1k97l" said:
I installed the current program I have on another computer, it gave the same error, I think the problem was caused by the program lock. I tried the cases, it still doesn't work
Install version 8 of Teamviewer and call us. Let's access your computer remotely and examine the problem.
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions The raft floor trestle irons must be at least 14. 8 is very thin. Screen and column shoots listed on the side should be listed either at the base only or on the screen only. In some projects, an iron order is given over the sheet thread reinforcement list. It is okay to show the sprouts on the raft as a reinforcement drawing, it should be either on the radial or on the curtain in the reinforcement table.
"sereze":ainjw5zo" said:
Radye floor trestle irons should be at least 14. 8 is very thin....
Hello, The diameter of the trestle reinforcement can be changed from the raft flooring properties.
In some projects, iron order is given through the sheet thread reinforcement list. It is okay to show the sprouts as reinforcement drawing on the raft, it should be either the radial or the curtain's in the reinforcement table
The foundation of columns and curtains Reinforcing sprouts are given in the tables in the vertical expansion of the column and the curtain details.They are not shown in the tables in the basic application plan.Could you add a sample project where you encountered a different situation?
Re: Opinions and questions about the use of ideCAD Reinforced Concrete 8 I'm sorry, I wrote it in the ide 8 section. My file will be ide7, if what you said is also valid for ide7, the file is attached
* The possibility to change the diameter of the trestle reinforcement is also valid for version 7. *Reinforcement table is not created in column vertical expansion and wall details in version 7. It is created in column application and foundation application plan. In version 8, foundation shoots are only displayed in the reinforcement table in the column application plan.
"özdemirözer38":5xxxdf2h" said:
I use idecad 8 program, after creating optional reports, when I try to save them as pdf, it gives an error and the program closes. What solution would you suggest?
Hello, Can you attach the project itself and the report you created as pdf to the message as rpt?
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions In idecad 8 version, while getting the detail drawings of the stairs, the program closes, even though I define the account axis supports, I get the same error.
