cassabotanic
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions Comparison of ideCAD Sap2000 on the column
"özdemirözer38":ra5mok7b" said:I use idecad 8, as I mentioned before, when I want to save the report as pdf, the program closes automatically.
Can you attach the project itself and the report you created as pdf to the message as rpt?="HakanŞahin":ra5mok7b"]Hello, the project itself And can you attach the report you created as pdf to the message as rpt?"özdemirözer38":ra5mok7b" said:I use idecad 8 program, after creating optional reports, when I try to save them as pdf, it gives an error and the program closes. What solution would you suggest.
You need to add the project."özdemirözer38":1v4do3rb" said:rpt extension is not accepted, it creates a problem in this way
In the near future, ideCAD WILL NOT ADD MASTER BUILDING DESIGN. There is no masonry design in the seventh version and it has become the most preferred program as of ideCAD 7 version. Maybe we'll plan for the ninth version. You do not upgrade to the eighth version, but when the time comes, you will upgrade to the ninth version if the version meets your requests. If it still does not meet your expectations, you wait for the tenth version. Best regards, İsmail Hakkı Besler"AGLC":xwjo6xvo" said:Dear Mr. Ismail. I agree with the views of a friend named "ganymede" I do not think that ide8 will be preferred much unless there is MASTERING BUILDING DESIGN in reinforced concrete. The reason is that ide7 works in excess for a normal building design, especially in rural areas. The features you mentioned for ide8 do not bring additional features for normal residential buildings (buildings that are not too high and not an extreme situation). The buildings built here are usually masonry. We also try to get a formwork plan from ide7 and make the calculations in excel (I don't think it's healthy).Completing a masonry project done in this way is more troublesome than a carcass building.I also have ide8 for reinforced concrete other than steel. I thought it would be a masonry building design, but unfortunately it doesn't exist. I don't think that there will be a transition from ide7 to ide8 reinforced concrete as long as it works. Ide7 is pretty much doing our job anyway.
Sir, don't wait in vain, it won't come It would have been enough if you said, "It seems that you never have such a plan. In this case, it would be more logical for me to buy a program that does stack design instead of update."Ismail Hakki Besler":caokz31q" said:In the near future, ideCAD WILL NOT ADD MASTER STRUCTURE DESIGN.There is no masonry design in the seventh version, and it is the most preferred program. ideCAD is as of version 7. Maybe we plan on the ninth version. You don't upgrade to the eighth version, but when the time comes, you can upgrade to the ninth version if the version meets your demands. If it doesn't meet your expectations, you wait for the tenth version. Best Regards İsmail Hakkı Besler
We have a program plan that does masonry design, but it is not a priority for us."AGLC":3d7a99vs" said:Teacher, it was enough if you simply said, "Don't wait in vain, it won't come." It seems that you never had such a plan. In this case, it will make more sense for me to buy a program that does masonry design instead of update."Ismail Hakki Besler":3d7a99vs" said:In the near future, ideCAD WILL NOT ADD MASTER STRUCTURE DESIGN. There is no masonry design in the seventh version and it has become the most preferred program as of ideCAD 7 version. Maybe we'll plan for the ninth version. You do not upgrade to the eighth version, but when the time comes, you will upgrade to the ninth version if the version meets your requests. If it still does not meet your expectations, you wait for the tenth version. Best regards, İsmail Hakkı Besler
"unver":1dpqs1ej" said:Go to the formwork plan section, create a foundation as in reinforced concrete. Take it easy Unver ÖZCAN
"saridurmus" said:Thank you, yes it did.
exactly There are no problems, there are problems, but the analysis is being done."NYILMAZ":1616pvh4" said:There is no problem. I tried it without touching anything. It's analyzing. There may be a problem with your computer.
Can you add the problematic project?"metinkacar":17500iss" said:I discovered the problem..When I open the project directly in ide8 and analyze it, it gives the error I mentioned. There is no problem when I open it in ide8, interesting situation...
