yurtsever58
Re: Opinions about using ideCAD Reinforced Concrete 8 questions WHEN I GO TO DRAWING STAIRS IN DESIGN, THE SYSTEM SHUT OFF AUTOMATICALLY AND THE PROGRAM FAULTS.
Actually There is nothing to fix. It stays like that on the screen. When you switch to another window and come back again, you will see that it has been moved to the place it needs to be moved."aykut_k":2545b35k" said:When I move the object with user-defined raster in it, the contours move but the scan stays in the same place. How do I fix it?
Hello, This problem is within our knowledge and has been fixed. We are currently using the last digit of the elasticity module for solution. it will be enough to delete and re-enter. Good work"sates":2lw6orm4" said:When the concrete class is changed, the shear modulus becomes inf.
If you add the project, we can look at your question."legend":rg8raru2" said:Hi, I couldn't find it in the topics. The problem is that the number of dynamic modes is insufficient! After closing and reopening or creating a contour line, the problem goes away. is there a problem?
I opened your project, I analyzed. 15 modes are sufficient. "The number of modes is insufficient warning" does not occur."legend":16dlesgc" said:project bak file is attached.
If you call our Bursa office, we can look into your problems remotely."legend":49y9ahbb" said:FREQUENTLY THE PROGRAM IS CLOSING. IS THERE ANYTHING I NEEDED TO DO AT 8V. I WAS A FAULT IN MY INSTALLATION. NO PROBLEM ?
