Insights on Using Architectural Design Questions
Re: opinions on using ideCAD Architecture 7 questions Hello, it would be better if you define the light inside. Like in real life, when it's sunny outside, it's barely visible if there's no light inside. I also defined a light source in the project in the link I gave. You can also make a lighting suitable for the effect you want to get. Good work
"erturan":2iz6x1hg" said:
"Arzu Dural Gök":2iz6x1hg" said:
Hi, you can review the different values and results in the link below. If you keep the reflection values less than in the example and increase the transparency even more, you can achieve the desired result. Good work
Hello, As you can see in the pictures below, the inside of the glass is visible while I am doing my work. After rendering, the inside is not visible, what do I need to pay attention to to ensure the visibility of the inside of the glass?
Thank you, Ms. Arzu, I benefited from the example. I couldn't get the image. When I looked from the outside, I couldn't see through the glass clearly. Could it be because of the light outside?
Re: Opinions about using ideCAD Architecture 7 questions Hello, I think there will be no problem in this way, we will try it when possible and see the result. Thanks you very much. Good works.
"KUBA2009":bw04uic4" said:
Hi, I have some questions and problems on page 12, I wonder if it hasn't been examined yet?
Hi,
related error export as dwg Warning
In your project, the colors in the scan options in the wall settings do not match the original scan and colors in the program (probably a project file with different settings was opened in the very old version) This is the reason for the message encountered in dwg export. If bring-[/b] is called, the problem is solved.
Also, when moving or columning in the program, when selecting the object and determining the base point, there is a problem in the image scale when I select another part of the entire drawing on the screen with a zoom window. I tried to explain this in the picture I added.[ /quote] This is image related. If the ouse wheel is moved a little, it seems to improve.
3- there is a problem with autoscan sensitivity, it doesn't work like other cad programs. The scanned parts in the section in the file I attached were made with automatic scanning, but I cannot make the wall parts.
A closed area is not formed so that automatic scanning is done above and below the wall. In order to automatically scan the wall section, a line must be drawn above and below.
4- Displaying the area and x, y coordinates of the objects drawn with the route object, with a command or in its feature. (The purpose of my request is not to wander the area repeatedly while calculating the area. In order to do this, it is necessary to write the coordinates on the screen with the text command, by stopping the coordinates with the line command on each corner, and writing down the numbers one by one from the coordinate box. The easy way is to transfer the drawing to autocad and draw around the land and the building with the polyline command and then list it. command, copy the coordinates with ctrl+c, paste them on the screen and dwg imprt to the ide again. I couldn't find an easier way to make the coordinate lists in the file I added.
5-symmetrical in the drawing I added Although the marked walls drawn with , the attachment features are the same, their scans on the screen look different. I wondered why.
In the wallscandifference.cde file you added, the scans of the wall settings and the scans of all the drawn walls are different from the program's default and original scan colors. This may be due to the use of project settings from an old version. Your suggestions and observations have been added to our notes. Good work
Re: Opinions questions about using ideCAD Architecture 7 FIRST THANKS A LOT FOR YOUR INTEREST.
"Levent Özpak":37sjz7y6" said:
"KUBA2009":37sjz7y6" said:
Hi, I have some questions and problems on page 12, I wonder if it has not been examined yet?
Also, when moving or colonizing in the program, when selecting the object and specifying the base point, there is a problem with the image scale when selecting another part of the entire drawing on the screen with the zoom window. I tried to explain it in the picture I added.
This is about the image. If the mouse wheel is moved a little, it seems to improve. IS THERE ANY EXPLANATION FOR THIS SITUATION? SO THE INTERESTING SITUATION HERE IS RELATED TO MY MACHINE, OR IS IT THE PROGRAM?
A closed area is not formed so that automatic scanning is done above and below the wall. In order to automatically scan the wall section, a line must be drawn above and below. In a very detailed drawing, which has become an unnecessary application, lines will appear on top of each other or piece by piece, so it is out of automaticity. so manual browsing is easier.
4- Displaying the area and x, y coordinates of the objects drawn with the route object, with a command or in its feature. (The purpose of my request is not to wander the area repeatedly while calculating the area. In order to do this, it is necessary to write the coordinates on the screen with the text command, by stopping the coordinates with the line command on each corner, and writing down the numbers one by one from the coordinate box. The easy way is to transfer the drawing to autocad and draw around the land and the building with the polyline command and then list it. command, copy the coordinates with ctrl+c and paste it on the screen and dwg imprt to the ide again. I couldn't find an easier way to make the coordinate lists in the file I added.
The land borders can be created with the land polygon command and the coordinates of the points can be seen in the Land Settings. it's a long job As I wrote above, a point or line (it is necessary to write down the numbers from the coordinate box one by one by stopping with the line command above each corner and writing it back to the screen with the text command.) My request is to be able to easily transfer it to the text command, that is, to draw the land and then see the coordinates in the settings does not work for me. In addition, the area command is not filled with the area command each time, but a coordinate area, etc., in the property of a route object that we will draw once. It would be more useful to have other features. Thank you very much for your interest in my determinations and suggestions. Your suggestions and determinations have been added to our notes. Good work
"KUBA2009":36lp8zga" said:
Also, when moving or columning in the program, after selecting the object and determining the base point, a zoom window is placed on another part of the entire drawing on the screen. There is a problem in the image scale when I select it with. I tried to explain it in the picture I added.
This situation is related to the image. If the mouse wheel is moved a little, the image is corrected. ? SO THE INTERESTING SITUATION HERE IS RELATED TO MY MACHINE, OR THIS IS THE PROGRAM.?
A situation arising from the program and it has been added to our notes.
Re: opinions on using ideCAD Architecture 7 questions Hello; I want to remove the separator wings of the window in the image, or I want to add an additional separator, I tried to do this with idecad ODT and I couldn't. Can you help? Can we change the design of existing doors or windows? Thanks.
Re: Opinions about using ideCAD Architecture 7 questions Hello Again, there are a few things he is curious about.??? 1st : I wonder if my idea in the automatic scan is among the notes ? 2.si: Displaying the area and x , y coordinates of the objects drawn with the route object with a command or in its property. and that it can be easily added next to the drawings on the screen( the purpose of my request is not to wander over and over again while calculating the area. I want the provincial municipalities in the architectural project to show the coordinates of the land and building corners in the architectural project. In order to do this, the coordinates should be lined above each corner. You need to stop with the command and write down the numbers one by one from the coordinate box and write it back to the screen with the writing command. The easy way is to transfer the drawing to autocad, draw around the plot and the building with the polyline command, then copy the coordinates with the list command with ctrl+c and paste it on the screen again. It goes through imprt. I couldn't find an easier way to make the coordinate lists in the file I attached. The land borders can be created with the land polygon command and the coordinates of the points can be seen in the Land Settings. But there is no area event, unfortunately. This is a longer job that you specified already wrote a point or line above As I said (it is necessary to write the numbers one by one from the coordinate box by stopping with the line command on each corner and writing it back to the screen with the text command). My request is to be able to easily transfer it to the writing command, that is, to draw the land and then see the coordinates in the settings does not help me. In addition, the area command is not filled with the area command each time, but a coordinate area, etc., in the property of a route object that we will draw once. It would be more useful to have other features and to be able to easily add them next to the drawings on the screen. Thank you again for your interest in my determination and suggestions. Good work.
"KUBA2009":lezu890x" said:
Hello Again, he has a few questions to ask. si: The area and x , y coordinates of the objects drawn with the route object can be displayed with a command or in its property. And it can be easily added next to the drawings on the screen( the purpose of my request is not to wander over and over the area while calculating the area. On the other hand, the provincial municipalities I have been in want the land and building corner coordinates to be shown in the architectural project. To do this, it is necessary to write the coordinates on the screen with the line command on each corner, note the numbers one by one from the coordinate box and write it to the screen with the text command. transfer it, draw around the land and the building with the polyline command, then copy the coordinates with the list command with ctrl+c and paste it on the screen and dwg imprt to the ide again. going through. I could not find an easier way to make the coordinate lists in the file I attached. The land borders can be created with the land polygon command and the coordinates of the points can be seen in the Land Settings. but unfortunately there is no field event. This is a longer job that you specified. As I wrote above, a point or line is required to be written on the screen with the text command by stopping the numbers from the coordinate box one by one by stopping with the line command above each corner. Seeing the coordinates in the settings doesn't work for me. In addition, the area command is not filled with the area command each time, but a coordinate area, etc., in the property of a route object that we will draw once. It would be more useful to have other features and to be able to easily add them next to the drawings on the screen. Thank you very much again for your interest in my determinations and suggestions. Good work
In my previous answers, I stated that your requests and findings were added to our notes. Also, as Admin has stated many times before, "every suggestion and request posted on the forum is read and evaluated by us, even if no response is written. Good work.
Re: Opinions about the use of ideCAD Architecture 7 questions Hello, First of all, we would like to thank everyone who contributed again for taking into account the ideas and requests of our users. I'll have a few ideas for the development of some new features I need. THE NEW ANGLES WE ADDED TO POLAR TRACKING WHILE DRAWING A LINE OR ANOTHER OBJECT WORKS FINE, BUT THE POLAR TRACKING DOES NOT WORK WHEN DRAWING THE MEASUREMENT LINE LINE. TO GIVE THE MEASUREMENT 2090 ON THE SCREEN, YOU WILL NEED TO USE THE PARALLEL OR VERTICAL REFERENCES FOR EACH DIFFERENT ANGLES. THIS PROCESS CAN WORK BY CHANGEING THE WORKING PLAN, BUT IT WOULD BE MORE USEFUL THAT WAY, I THINK. ALSO, WHILE MEASURING 2172 MEASUREMENT ON THE SCREEN PERGOALLY TO THE PASEL EDGE, IT WILL BE VERY USEFUL TO USERS IN LOCKING THE VERTICALLY WHEN THE CURSOR CLOSE TO THE PARCEL EDGE OR THE NEAREST OBJECT I tried to express it in the picture I added, good work
Re: opinions about using ideCAD Architecture 7 questions
"Arzu Dural Gök":x8d159wc" said:
hello, I prepared a helpful video (The recording is not audio.) Good evening...
"erturan":x8d159wc" said:
Hi ; I want to remove the separator wings of the window in the image, or I want to add an additional separator, I tried to do this with idecad ODT and I couldn't. Can you help? Can we change the design of existing doors or windows? Thank you.
Hello; Thank you very much, Ms. Arzu, it was very nice and explanatory. Good luck to you. I will try to make it myself, if not, can I ask you to share the model you made? :)
"Arzu Dural Gök":5nmj7wx5" said:
You're welcome, I'm sending it anyway, hoping you've done it :) Good work...
Thank you very much Thank you :) Good work.
Re: opinions about using ideCAD Architecture 7 questions hello, when I add a picture to the architectural project sheet, I can't get the output of the project? can you help?
"akif tekin":2jb7lnje" said:
hello, when I add a picture to the architectural project sheet, I can't get the output of the project? Can you help me.
Hello Akif, Tell me I printed the project you e-mailed with the HP DesignJet500 brand plotter as illustrated in ideCAD version 7.015. Output dimensions 60cm x 1200cm You may be experiencing problems due to the plotter settings you are using or the insufficient plotter memory.
Re: Feedback questions about using ideCAD Architecture 7 Hello. After starting the rendering with version 7.015, is there a chance to unlock the program and continue drawing on another computer? I've heard that there will be such a feature in the new version before. After starting the render, when I remove the lock, the rendering process continues for a while. However, after a while, it gives an error that the lock could not be found. I would be very pleased if you inform me.
Re: Comments on using ideCAD Architecture 7 questions This feature is valid for the ideCAD Render program. If you remove the lock in the architectural program, it will give an error message.
Re: Opinions and questions about the use of ideCAD Architecture 7 Could you please give information about the additional possibilities that the idecad render program will bring different from the idecad architecture program?
