Re: opinions on using ideCAD Architecture 7 questions Hello, first of all, there are bug reporting rules before reporting problems on forum
please read the link. You wrote that ideCAD Architecture is very slow. It is not the right approach to write a comment as "NO PROBLEM IN PC SPECIFICATIONS (EVERYTHING IS HIGH LEVEL) BUT IDECAD IS VERY SLOW" instead of specifically stating the situation you encounter with slowness. I would like to think that you wrote this statement in good faith in reference to the 5th article, where it follows that you cannot fully use the possibilities of the program. If you are going to use detailed trees or other libraries a lot in the program, in order to work efficiently in the perspective window, you should select the
3D contour option from the library settings. While the tree appears as a rectangular prism in perspective, render render It will output as a real tree model. That way you work pretty fast. If you want to work quickly while performing operations such as zoom and pan in the plan; From the image menu, you can enter object contour drawing and have your libraries drawn as outer contour.
This kind of optimizations should be in professional working programs and they are available in ideCAD. I can also make another suggestion. As you can see in the attached project, copy the attached library object to the libraries folder in the folder where the program is installed. With the same logic in our human silhouette library, you can use the tree silhouette in your projects. While your trees occupy the space of a zero-thickness surface in the plan, their renders will appear as real tree images. Like pasting people, trees etc in painting programs or RPC logic. Moreover, the real shadows will appear in the render. Working this way also shortens the render time.
Apart from this question, are there any situations where you experience slowness? If there are, you should report them to the forum or technical service with sample projects, as I wrote above; This is the problem, this is the solution so we can help. Otherwise, generalizing and saying it is slow will not help you, and it will unnecessarily mislead forum participants. In item 6, you wrote "in many projects, when we add a floor profile object, that is, a floor deletion, when we want to change it, the program gives an error and closes itself". Which project has a problem at which stage? Defining vaulted windows, opening spaces and horizontally angled walls are registered in our wish list. Good work
"RauLWalker":2szbg6qa" said:
Problems with İdecad 1-) Any project worked in İdecad is too large 2-) Not being able to give the desired slope to the wall (only happens on the curtain wall) 3-) After using the vaulted roof as a wall and bending the end then we can't say that we can't give a round window space to the vertical vault, we can't say cut it with the roof 4-) MOST IMPORTANT, CANNOT FEATURE THE WALL OR ANYTHING IN IDECAD (FOR EXAMPLE, IN 3DSMAX, WE WANTED TO CHANGE WITH POLY PROCESS. ) THESE PROPERTIES ARE VERY GOOD IF THE PROCESS IS RELEASED. IT SLOWS THE PROJECT IF THE TREES DO NOT LOOK LIKE A TREE IN THE PLAN AND IN NORMAL PERSPECTIVE ONLY WHEN RECEIVING THE TREE, IF THE TREE IS APPEARING, THE PROGRAM WILL BECOME LESS THROUGH PC SPECIFICATIONS NO PROBLEMS (EVERYTHING IS HIGH LEVEL ) BUT we have a lot of bugs in the program we want to change, that is, IDECAD has a lot of errors in the project we want to change. it gives and shuts itself down
