Re: Opinions about the use of ideCAD Architecture 7 questions Hello, First of all, I would like to thank everyone who contributed and gave ideas, thank you. I apologize in advance if there are any spelling mistakes in my writing. It should be something that caught my eye quickly and giving errors etc. The situations are as follows: TO THE END OF THE ITEMS OF THE RELATED SUBJECT ( ARCHITECTURE + STATIC ) TO INDICATE WHICH PROGRAM MY REQUEST IS RELATED TO. Since these versions are known beta, we respectfully recommend that the additions be made until the final version and the additional version that will be released.s 1-polar monitoring: The addition of the 1-pole monitoring was superb, but it was made for limited works, not only for the slab edge, curtain beam line, but also for all works where the distance and angle can be entered with the drawing. A few examples to be added: first, it should be precise in the route and route reinforced commands, then it will be very nice to be activated and optionally added in all operations such as scanning, profile object, railing, stairs, rotation and similar operations. ARCHITECTURE + STATIC 2-ladder settings, 2, I cannot enter the settings of the arm, the program closes. ARCHITECTURE + STATIC 3- My most used layer hide show - lock unlock commands are only available in the change menu When I add it to the toolbars, it appears as text and does not change and occupies a huge space. It would be very useful to be able to change and change the image/text appearance of all commands. ARCHITECTURE + STATIC 4- Selecting none button in reinforcement selection. There are so many reinforcement signs, it's a waste of time, I think. STATIC 5-stair drawing is very confusing, especially if there is a setting for the cross section marks or something, I wonder if I did not find it? It will be better if there is an option to select with a claw in the STATIC 6-MOVE FAST command. For example, moving the cross section of a block detail or the body drawing more easily will make the quick move command even faster. The formwork and concrete quantity of the STATIC 7-stair is not visible. If there is a feature to select with color or layer for STATIC 8-primitive objects, ARCHITECTURE + STATIC 9-When we double-click on the text, the Text Properties window and the Change Text window will come up, it will be better to combine these two windows. I guess you don't use much formatted text. Because we choose to change the text. Then you need to select it again in the window. For partial changes in a long writing process, the formatted text is different. In other words, if I break a text written in paragraphs with normal text, with the object split command, line-by-line editing can be carried out, but there is no formatted text. 10- It is necessary to have more options in the measurement marks. Arrow, thick notch, solid circle, etc. ARCHITECTURE + STATIC 11- Option to change the direction of the texts while taking symmetry. ARCHITECTURE + STATIC 12 - Adding and changing the shortcuts on the command line by us. And the removal of the English-Turkish language confusion here (I, as a 12-year-old user, used the zoom window command as ctrl+z and finger memorization occurred. There are a lot of similar commands I use. Now I will get used to the command line, if there are more options and if there is a possibility to change it, of course.) ARCHITECTURE + STATIC 13- Especially removing the English terms on the grate or explaining them in an easier way with the help menu will be the easiest solution. Of course, it would be better if this help menu is explained with explanations such as graphic pictures etc. ARCHITECTURE + STATIC 14- With the block command, we can change the colors of the objects we block in the block settings, such as color thickness line type. As soon as we need to smash this block, it returns to its first given properties. I couldn't figure out why it works that way and what it does to us. When you split it, it will be more useful to keep its current properties and break it up. ARCHITECTURE + STATIC 15--You can see the effect distance of the reinforcement calculation axes on the floor plan and can be changed easily with the mouse, and -Optionally, the validity distance of the reinforcement axes in the formwork plan is displayed when the axis is moved or the calculation axes change, but the validity distance indicated by the arrow is old. it stays like that. When we press any key from the STATIC 16-Toolbar, this command appears on the command line, making it easier for us to learn the definitions assigned to the commands. It also increases the usability ARCHITECTURE + STATIC 17-The ability to adjust the properties of commands such as Offset, Fillet on the command line ARCHITECTURE + STATIC 18- these are the processes that I have noticed and requested to be added for now. We will try to convey our congratulations and wishes regarding static and rendering as we use them. Respects.
