HakanŞahin
Administrator
Fixes reported in this topic on the forum and fixed in version 7.013:
"nulkucu":2sov55ai" said:static 7 why I can't get report outputs
"batifon":2sov55ai" said:good luck to all ide users. I am having a hasp problem while installing it, it gives an error while installing hasp in the 64 bit version, then it continues. After the program is installed, the program opens and closes itself why
In beam settings, beam rigid arm lengths d1 and d2 values were given as 1 meter. A warning is now given in the program for such changes."excalibur_24":2sov55ai" said:I ANALYZE WITH SEMI-RIGID DIAPHRAGM. .WHY DO I KNOW? I'M USING WINDOWS 7.
"Bolvadinim":2sov55ai" said:Hi.. 32 bit xp de ..I can't get a report. What is the reason?
"buzadaM":2sov55ai" said:I'm using windows 7 64bit ide 7.01 static and I installed the architecture. After opening both programs, it gives the following error and closes; [bideCAD_Static_7_x64.exe has stopped working, help I'm waiting, I'm using avast antivirus by the way
"excalibur_24":2sov55ai" said:I also get a warning that mdbthunk has stopped working while working in the program. I wonder what this means
"Bolvadinim": 2sov55ai" said:Spacing values from joint point to joint point are used in the calculations, there is a connection inside the columns as reinforcement, these are ok. Dimensioning should be based on the span between the two columns while drawings are being made. I added the sample project that shows the problem.
"a_karagullu":2sov55ai" said:if we could enter from the command line in object fragmentation.
"NYILMAZ" :2sov55ai" said:I'm having the same problem with V6 as well as V7. The accessory calculator does not work. Could it be your reason?
"oyuxel":2sov55ai" said:V7 command line has case distinction. does not recognize capital letters.
The F1 key opens the relevant help topic in dialogs or while running commands."ryildiz":2sov55ai" said:2-) " What is this" in the reinforced concrete menu no feature. It is installed at 6.54 on the PC and it is working on it.
"ryildiz":2sov55ai" said:1-) While there is no B2 irregularity in the Irregularity report in the earthquake regulation general report, it says that there is B2 irregularity on the ground floor in the x direction on the detail page. And it is not printed on the first page. What is the reason? it says "TDY article 2.3.2.4 - With B3 irregularity, the internal forces of the element are increased."
"NYILMAZ":2sov55ai" said:In the past, we could select more than one slab and enter a reinforced concrete calculation axis. This allowed us to have the internal dimensioning in the same direction in the mold plan drawing. I don't think this is the case in V7.
"KUBA2009":2sov55ai" said:3- my favorite layer hide show - lock unlock commands are only available in the change menu.When I add them to the toolbars, they appear as text and do not change and it occupies a huge space .
