"oyuxel":25gj64gq" said:
Hello, when I'm taking a mold plan drawing, the dimension on the axis is "0". How can I fix this.
Sometimes there are axes on top of each other. Then it gives zero distance. Actually, it seems like it doesn't accept the axis one after the other, but in a way that I don't understand in what condition, there were axes one after the other.
Why are the object names not in alphabetical order in "Layer Settings / Object Drawing Details"? For example, the axle is somewhere down. Wouldn't it be better if it was alphabetical?
"NYILMAZ":2f0qc6zk" said:
"Layer Settings / Object Drawing Details" in why the object names are not in alphabetical order. For example, the axis is somewhere below. Wouldn't it be better if it was alphabetical?[/quote ] Yes it would be great, it should be..
It would be nice if jeans dimensioning was also included in the pattern plans. They ask from the room, I often forget.
"oyuxel":1ixrf28r" said:
would be nice if the jeans dimensioning was included in the pattern plans. They ask for the room, I often forget it.
jeans sizing is already available in the pattern plans... Jeans for each floor can be selected from the dimensioning section so that the denim dimensioning in the formwork plans You have to measure it, then jeans come out automatically in the pattern plans...
punching control for curtains (20/140 curtains are disadvantageous from 35/70 column), punching checks on non-radiate foundations.
"NYILMAZ":2lwglhz8" said:
Friends, I wish everyone a nice Monday and a happy week.
I wrote the above message both for good wishes and to see the system clock again. The forum clock has not turned back one hour, it is still ahead. I think it's in the app. ;)
"nahroyo":jf8q3ags" said:
"oyuxel":jf8q3ags" said:
would be nice if jeans dimensioning was also included in the pattern plans. they ask from the room, I often forget.
jeans dimensioning is already available in the program in the formwork plans... you have to measure the denim for each floor from the dimensioning section in order for denim to come out in the formwork plans, then the denims will automatically come out in the formwork plans...
that this is the case I know that already. Like the internal dimensioning I mentioned, it came out on its own without me doing it. I was talking about the option to get it automatically by marking it in the drawing / mold plan / advanced settings tab. again thank you for sharing.
Reintroduction of pushover analysis into the program is not planned *for V7*. ideCAD 7 will be available as seen in beta (7.01).
My computer's frequent errors are due to the fact that it is a laptop, and the three-dimensional drawing features are turned on. Hakan examined my laptop with a remote desktop connection and since I turned off these features, it's the 3rd day and I haven't experienced any error messages or shutdowns. Last night, I got a 150 dpi and 8000*6000 pixel render that took 20 hours without any problems. Announced to friends who use laptops...
I am trying to solve a pool account by giving lateral loads to the curtains because the pool module is not complete. but there are some combinations that I don't want to be used, when I delete them, they come back when I analyze them. I add combinations, but I can't delete the automatic combinations. Is there a way?
"metinkacar":16kjwpfw" said:
I am trying to solve a pool account by giving lateral loads to the curtains because the pool module is not completed. But there are some combinations that I do not want to be used, when I delete them, it comes back again. I add combinations but I cannot delete the automatically received combinations. Is there a way?
You didn't write which combinations you needed... we didn't give the opportunity to change the automatically created combinations in the program because they are the ones that should be used as per the regulations. However, you can change the fixed and live load coefficients in the analysis settings (for 1.4G+1.6Q).. You also have the opportunity to ignore the earthquake effects by making the building importance factor zero, and to reduce it by giving a value between 0 and 1. Thus, you can activate the newly added combinations in the selection of reinforcement... I don't know if it fits your purpose... Good work...
