Could you add the original version of the project in version 6 to the message? (unopened and not saved in version 7)"ahmetkale":33iidh4e" said:D01 tile, which looked normal in version 6, gave an irrelevant double reinforcement error in version 7, what is the reason for this
Hello There was a problem with the beam K01 and the slab connected to it. Redefining the beam and the slab fixed the problem. You can use the attached project.As I wrote in the previous message, it would be better if you add the 6 versions of the project to the message."ahmetkale":25cb4hph" said:The D01 slab, which looks normal in version 6, gave an irrelevant double reinforcement error in version 7. What is the reason
"HakanŞahin":jufc5sye" said:Hello, Yes it is possible... There are .blk files in the "Annotations" folder under the program folder. These files are the details to be shown on the titles, and the files with txt extension organize the detail group. After recording your own details as blk, create your own layout by taking the txt files in the folder as an example. (or add to existing txt files) The created file will be seen as a list in the title section of the drawing settings. The title group you selected from the list will be drawn in the drawing. Example txt file content: HOW TO SAVE blk FILE?"nahroyo":jufc5sye" said:IN THE SETTINGS OF "LETTERHEADS" IN THE DRAWING SECTION, THERE ARE SEVERAL DETAILS THAT ARE EXISTING IN IDECAD. CAN WE USE THE SPECIAL DETAILS USED BY OURSELVES AND WE NEED TO USE THE PROJECT? HOW IS THIS POSSIBLE... IF IT IS POSSIBLE, IDECAD AUTHORITIES SHOULD CONTACT THIS ISSUE..."HakanŞahin":jufc5sye" said:THERE IS AN ERROR IN THE K01 BEAM AND THE FLOOR CONNECTED TO IT BUT HOW DID YOU FIND IT?"ahmetkale":jufc5sye" said:For Black Background Letterlet_1.txt .\Black 01_PaftaRevScaleDate.blk .\Black 02_DesignDrawerControlAdvisor.blk .\Black 03_ProjectName_Paper. .blk .\Black 06_BuildingOwner.blk .\Black 07_StructureSchematicImpression.blk .\Black 08_SoftwareLogo.blk .\Black 09_MaterialFloorEarthquake.blk .\Black Note3_Patterns_Black Note. It will be prepared as ]mytxtfile.txt[/b]: .\myblogfile.blk .\mysecondblockfile.blk .\mythirdblockfile.blk..."ahmetkale":jufc5sye" said:The D01 slab, which looked normal in version 6, gave an irrelevant double reinforcement error in version 7. there was. Redefining the beam and slab fixed the issue. You can use the attached project. As I wrote in the previous message, it would be good if you add the 6 versions of the project to the message. Good work
During the slab analysis, follow the slab meshes... There is distortion on the K01 side (mesh lines are from the complete slab system) You'll notice that it's broken..."HakanŞahin":1tv2m980" said:There is an error in the K01 BEAM AND THE FLOOR CONNECTED TO IT CORRECT.. BUT HOW DID YOU DETECT IT?
.blk HOW TO REGISTER WITH THE EXTENSION. ?"HakanŞahin":2vur98t4" said:Hello, Yes it is possible... There are .blk files in the "Annotations" folder under the program folder. These files are the details to be shown on the titles, and the files with txt extension organize the detail group. After recording your own details as blk, create your own layout by taking the txt files in the folder as an example. (or add to existing txt files) The created file will be seen as a list in the title section of the drawing settings. The title group you selected from the list will be drawn in the drawing. Sample txt file content: Letterlet_1.txt .\Black 01_PaftaRevScaleDate.blk for Black Background .\Black 02_DesignDrawerControlAdvisor.blk .\Black 03_ProjectName_Pattern.04Project. blk .\Black 06_BuildingOwner.blk .\Black 07_BuildingSchematicDisplay.blk .\Black 08_SoftwareLogo.blk .\Black 09_MaterialFloorEarthquake.blk .\Black Note3_Patterns.Black_Blk Notes. My owntxtfile.txt[/b]: .\myblogfile.blk .\mysecondblokfile.blk .\mythirdblokfile.blk will be prepared as..."nahroyo":2vur98t4" said:IN THE SETTINGS OF "LETTERHEADS" IN THE DRAWING SECTION, THE MAJOR DETAILS ARE AVAILABLE IN THE SETTINGS OF IDECAD, IF WE CAN ADD THE SPECIAL DETAILS USED BY OURSELVES, CAN WE JUST USE THE SPECIAL DETAILS USED IN THIS SECTION? HOW IS THIS POSSIBLE... IF IT IS POSSIBLE, IDECAD AUTHORITIES SHOULD CONTACT THIS ISSUE...
The window that exists on the screen during the slab analysis (shell analysis window) can either be moved to a corner of the screen or removed completely so that the meshes appear more smoothly on the screen.The same is true for the raft basic analysis."HakanŞahin":1rlpkgeh" said:Follow the slab meshes during the slab analysis... You will notice that there is distortion on the K01 side (the mesh lines are disconnected from the complete slab system for that tile)...
"NYILMAZ":5b8t1gzb" said:During the slab analysis, the window (shell analysis window) on the screen should either be moved to a corner part of the screen or completely removed so that the meshes can appear more smoothly on the screen. The same is true for the raft foundation analysis.[/quote ] Hello, Nedim, I did not understand the note you wrote... When you click OK after the tile analysis dialog appears, no open window is left on the screen anyway... Meshes can be observed easily... I guess we are not talking about the same issue... The first shell dialog that appears can be drawn with the mouse.
I think it may be related to computer performance or graphics card. But it always stays with me."HakanŞahin":25mg3uac" said:Hello, Nedim, I did not understand the note you wrote... After the slab analysis dialog appears, when you say OK, there is no open window on the screen anyway... Meshes can be observed easily... I guess we are not talking about the same issue.. The first shell dialog can be drawn with the mouse."NYILMAZ":25mg3uac" said:During the slab analysis, the window (shell analysis window) on the screen should either be moved to a corner part of the screen or be completely removed so that the meshes can appear more smoothly on the screen. The same thing applies to the fundamental analysis of the raft.
The reason for me to write the command where the problem stems from I need to see. but I was just browsing the project while I was drawing, even when I wasn't in any command. There is another problem such as pan, zoom, polygon column expansions are empty."SCETCHER":3a8hdfgy" said:"Ismail Hakki Besler":3a8hdfgy" said:We have gathered your opinions, questions and observations about the use of ideCAD Static 7 under this heading.
"SCETCHER":2vi6fqet" said:In order to write the reason, I need to see the command that caused the problem. However, while I was not in any command, I was just browsing the project while I was drawing. There is another problem such as pan, zoom, polygon column expansions are empty. I moved the axles to see if they need to go through the corner rather than the middle. Then I said drawing-column application plan, then I said goodbye to the project"SCETCHER":2vi6fqet" said:"Ismail Hakki Besler":2vi6fqet" said:we gathered your opinions, questions and observations about using ideCAD Static 7 under this heading.![]()
Could you add the project?"SCETCHER":2ykjcxm3" said:this is exactly the problem, I wondered if the axles should pass through the corner of the column, not the middle. Then I said drawing-column application plan, then I said goodbye to the project![]()
Hello I have added your requests to our work list. Thank you Good work."NYILMAZ":r80lqdce" said:Let's add options to Stairs reports such as "From All Floors/Selected Floor/Selected Stair", "Similar stairs" etc. Also, if the report If all of them are given together, it will be useful to make a definition.For example: +6.70 grass ladder reports... Also, I don't know why I found the column application drawing way in the old method more practical. For example, while drawing the plan, axis fonts etc. were adjusted. It may be necessary to adjust the column in the application. If it is forgotten, there will be differences this time. The pros and cons are discussed.
here you go."zeki78":fln01ycf" said:hi friends, can you save the attached file in version 6.54 and send it to me. Thank you in advance.
