Hello. About loads.. To make load libraries multi-layered, more detailed and transparent; Wall materials (brick/aerated concrete/pumice/stone/drywall), interior, exterior plaster (gypsum/concrete plaster), exterior elements (layers such as load-bearing construction, glass, aluminum, marble, granite, stone, sheathing, etc.) In the current beam load editor, similar to what is described in the floor load library, you can see the wall and wall substructure in the table below. All layers that make up the wall cannot be defined one by one, such as layer thicknesses, unit weight, plaster thickness, unit weight of plaster, etc. Result-i Word:New beam supported by visual shape, flooring we demand loads editor.. Thank you..
