the program closes after it is opened I am using windows 7 64bit ide 7.01 is static and I installed the architecture. for static ideCAD_Statik_7_x64.exe stopped working Issue signature: Problem Event Name: APPCRASH Application Name: ideCAD_Static_7_x64.exe Application Version: 0.7.0.10 Application Timestamp: 4ea01bfe Error Module Name: ntdll.dll Error Module Version: 6.1.7601.17514 Fault Module Timestamp: 4ce7c8f9 Exception Code: c0000005 Exception Distance: 0000000000027b11 OS Version: 6.1.7601.2.1.0.256.1 Local ID: 1055 Additional Information 1: 5bff Additional Information 2: 5bff94ac6c504d23a48390dcec0cb01d Additional Information 3: 4: e54a17f22b3852f79d9455c449341221 Read our online privacy statement:
If there is no privacy statement online, please read our offline privacy statement: C:\Windows\system32\en-GB\erofflps.txt for architecture ideCAD_Architecture_7_x64.exe has stopped working Issue signature: Problem Event Name : APPCRASH Application Name: ideCAD_Mimari_7_x64.exe Application Version: 0.7 .0.10 Application Timestamp: 4ea01bb0 Error Module Name: ntdll.dll Error Module Version: 6.1.7601.17514 Error Module Timestamp: 4ce7c8f9 Exception Code: c0000005 Exception Distance: 0000000000027b11 OS Version: 6.1.7601.2.1.0.256.1 Local ID: 1055 Supplementary Information 1: 5bff Supplementary Information 2: 5bff94ac6c504d23a48390dcec0cb01d Supplementary Information 3: e54a Supplementary Information 4: e54a17f22b3852f79d9455c449341221 Read our online privacy statement:
If there is no privacy statement online, please read our offline privacy statement: C:\Windows\system32\en-EN\erofflps.txt I am using avast antivirus by the way.
HakanŞahin » Oct 26, 2011, 17:14 excalibur_24 wrote:1.06 DA STAYS IN MODAL. WHY DOES IT? Can you add the project? If necessary, you can call me on 0 224 220 67 17. I sent it to MRB idecad mail address. I could not send it from here. The size is large.
WHEN I LOOK AT THE FEATURE TO TAKE MEASUREMENTS WITH THE DESIGN TOOLS-CONSTRUCTION COMPONENTS ICON. I ALSO LOOKED AT A LITTLE MIXED. YARDIM. I PRESS CREATE UNIT BUT I ALWAYS REVEAL m2. WHY HAS ACABA.OSKA YA YA VE AMP YEKONYAMIO FALAN FATHER.
"excalibur_24":2a4qf8f6" said:
I sent it to the MRB idecad mail address. I could not send it from here. The size is large.
destek@ideyapi.com.tr and [ We checked email=ideyapi@ideyapi.com.tr]ideyapi@ideyapi.com.tr[/email] addresses, a project from you has not reached us. Better upload it using ://www.hotfile.com/[/url]...
DO YOU HAVE 64-BIT XP? ALSO THE IDE DOESN'T WORK IN 7 XP AS I KNOW. IDE 7 64 BIT XP 32 BIT. TRY 32 BIT INSTALLATION
"umutozalit":1k4f39pp" said:
I am using a 64-bit xp program, I get this warning at startup
In order to install Microsoft Visual C++ 2010 Redistributable Package (x64) on 64-bit Windows XP, Service pack 3 is required. Then Microsoft Visual C++ 2010 Redistributable Package (x64) plug-in will be installed. Connected to the computer with remote access and the problem has been fixed...
"SCETCHER":1otzjunt" said:
DOES NOT WORK IN XP
The program works in XP, but there is a problem in this version when getting reports... It will be fixed in the update. I wrote the solution to the current report problem in my previous message.
I DEFINED SPECIAL LOADS IN LOAD LIBRARY IN MRB IDESTATIC. I HAVE COLOR SETTINGS TO OBJECTS IN OBJECT SETTINGS. HOW CAN I USE MY SETTINGS WHEN I OPEN THE PROJECT PREPARED BY MY BROTHER IN IDESTATIC? WHEN I OPEN THE PROJECT PREPARED IN IDEMIMARINE IN IDESTAT, WILL I ALWAYS HAVE TO MAKE THE ADJUSTMENT?
[Quote = "excalibur_24": 3qn1dr1s "] MRB İDESTATİK LOAD LIBRARY In CERTAIN Cargo TANIMLADIM.OBJ SETTING in the OBJECT to the COLOR SETTING FALAN VERDİM.KARDEŞİ's in İDEMİMARİ PREPARED PROJECTS in İDESTATİK I ON HOW TO USE my settings? İDEMİMARİ at PREPARED PROJECT İDESTATİK in the EEA when HEP setting DO I NEED TO BE? [/ Quote ] Hello, make a template in ideCAD Static. Then give it to your brother and your brother will use that template to make the settings related to ideCAD Architecture and save it as a template and return it to you. When starting your projects, start the project with the same template projects. In existing projects, when opening the project, "active pen" You can apply the colors of the last used project to the project you opened with the "apply color" option. The parameters entered in the element settings are kept in the file. Note: The project you sent has arrived and has been taken into our notes for review.
First of all, good health. 1-info: I want information about tape beam. I think it will be used on beamless floors. Does it participate in the analysis or will it only appear in the drawing like a constructive element? Do we have to use it when we make beamless flooring, is it okay if we don't use it.......? 2-request: It would be nice to be able to define different types of reinforcement placement in columns. especially in retrofit projects, it is needed when entering a project that has been done before. corners and edges may be different reinforcements. 3-request: It would be nice to complete the pool model in particular. (Analysis results and deficiencies such as drawing).
Band beams are not included in the analysis, they are only shown in the drawing with a certain amount of reinforcement. We enter the amount of reinforcement in the band beam settings. Belt beams are used at idle curtain ends in tunnel formwork projects.
Hello there; First of all, thanks for the new version. Indeed, even the semi-rigid diaphragm solution alone deserves the name of a new version. A statement made in ideCad 7 version caught my attention. The explanation is as follows
Corbaceous flooring solution with the whole building model (without using fictitious beams)
Does this mean that there is a requirement to define a fictitious beam when making a beamless slab solution in the previous version? Does the software check the conditions in the earthquake code for beamless floors? I have a suggestion for the next intermediate versions of ideCad 7. For example, when we double-click on the texts in the pattern plans, the Change Text window appears instead of the Font properties window. Or, as in AutoCad, I think it would be better to combine these two windows. Good work
"levent":1zeejkps" said:
Hi; First of all, thanks for the new version. Even just the semi-rigid diaphragm solution deserves the name of a new version by itself. A statement made in ideCad version 7 caught my attention. The description is as follows
Whole building cork flooring solution with model (without using fictitious beams)
Does this mean that there is a requirement to define fictitious beams when solving beamless slabs in the previous version. Does the software check the conditions in the earthquake code regarding beamless floors? ideCad 7 later versions I have a suggestion for you. For example, when we double-click on the texts in the mold plans, the Change Text window will appear instead of the Font properties window. Or I think it would be better to combine these two windows, as in AutoCad. Good work
In ide 6, the horizontal load of the system in mushroom floors fictitious beam definition required for its behavior Semi-rigid diaphragm cozu in ide7 This problem has disappeared with mu
Hello.. When taking the column application drawings, when the panels and columns are drawn together, the panel dimensions are not based on the net gap between the two columns. Correction takes time and can be overlooked. In calculations, the span values from the joint point to the joint point are used, there is a connection inside the columns as reinforcement, these are ok. While making the drawings, the dimensioning should be based on the gap between the two columns. I have attached the sample project showing the problem. Thanks..
All the boxes are checked in the reinforcement selection table and we are trying to remove it for two hours. Let's either give a standard reinforcement table or leave the boxes blank and choose it ourselves before the analysis. It is both a waste of time and stress.
"SCETCHER":o2u7gevm" said:
in the reinforcement selection table, all the boxes are checked and we are trying to remove it for two hours. Either we give a standard reinforcement table or let the boxes be empty and select it ourselves before analysis. It is both a waste of time and stress.
With the help of the template project, you make these and similar personal settings once and use them for life.
