"SCETCHER":38qi00a0" said:
I want to see the nd values in the reinforced concrete column tab. I don't know exactly what it does, but we could understand whether the column was forced or not.
Hello, The Nd value you want to see is the value in the F1(axial) line in the Columns/Forces reinforcement areas tab. F1(axial), M2(minor) and M3(major) values are combination values of column reinforced concrete. Although Nd is a value found from the most unfavorable load combination, some of our users or inspectors considered it to be only the axial load from the vertical and asked why it might not increase from top to bottom in some columns? It was misunderstood. That's why we removed it from the column tab... You can tell if the column is forced by looking at the column margin, not by the Nd value. Because Nd is not a criterion to be considered alone, it should be evaluated together with the bending moment in both directions. Its result is already stated as pursanta. Regardless of this, if we are going to control a column for the largest axial load, the program does this automatically. If the control is exceeded, the developer is warned with the E warning in the column reinforced concrete. In the column report, normal strength values are reported in detail under the title of "column normal strength control".
