"aykut_k":28oz9c8h" said:
hi, when my program was in version 6.54, the arial narrow option disappeared in the text section. I didn't bother to install 7 anyway. I installed 7 and it still doesn't exist. Why?
the font you mentioned under the windows folder fonts Copy and paste it into the folder. Then exit has nothing to do with the program.
"excalibur_24":19rjmgam" said:
I WON'T HAVE WHAT IS THIS FEATURE IN MRB 7. OR DO WE NEED TO DOWNLOAD THE DEMI PROGRAM FOR Windows 7 (WinHlp32.exe) FOR WINDOWS 7 AS AS IN THE PREVIOUS VERSION. SAID AND IT DID NOT WORK.
"HakanŞahin":19rjmgam" said:
Hi, What is this help has been removed because it is incompatible with 64 bit program structure. In version 7, dialogs have been edited to provide help when pressing the F1 key (it works for many dialogs now. For example, press F1 in column settings or press while in beam command), new and not yet helpful dialogs and commands are also working.[/quote ] However, it seems that your problem is not related to what it is. Check if the ideCAD_Statik_7.chm file under the program folder is working. (It should be opened by double-clicking) Normally, you do not need to do any installation in windows for the "chm" help file to work. If the ideCAD_Statik_7.chm file is running, when you press the F1 key in any dialog, such as the layer settings dialog, the help for that dialog should also open. Contact us for a detailed review. If necessary, we can access your question remotely...
I can't see the dome reinforcement areas in the project below, normally after the analysis, shouldn't there be reinforcement areas in the dome and vault reports in the reports? all are shown as 0 in the report.
"nahroyo":1rzeohhw" said:
I can't see the dome reinforcement areas in the following project, normally, after the analysis, shouldn't there be reinforcement areas in the dome and vault reports in the reports? Specify the support conditions of the dome (by ticking the line Supporting conditions for solution with the structure). Analyze by semi-rigid diaphragm. Reinforcement areas will appear in the 3D frame and report
"tavekkul":1wvp4ahi" said:
can you extract ide wrep 7 for the output so we don't have to save it as an old version.
The places of the sections are lost in the projects that I saved as an old version and printed out...
"tavekkul":2j9tzyra" said:
in the projects that I saved as old version and printed out, the places of the sections have been lost...
Hello, I thought you meant the section lines on the mold plan by section locations... there doesn't seem to be a problem... so that we can see the problem. Can you send the relevant project or describe it as we can.
"ahmetozates":1u8uj1eh" said:
greetings, I'm using idestatic version 7.013, I'm drawing a polygon column but it doesn't save your information
Hello, It's among our due diligences. Thank you.
"HakanŞahin":1gcl05vo" said:
"tevekkul":1gcl05vo" said:
in the projects that I saved as old version and printed out, the places of the sections were lost...
Hello, I thought you meant the section lines in the mold plan by section locations. .. there is no problem... can you send the project so that we can see the problem or describe it as we can do it.
After drawing the project with ide 7, I save it as the old version in ide 6.0012 and open it with ide wrep, the cross-section lines disappear.
Save in 6.54 format for output. In version 6.5 the new section possibility was introduced, it will be incompatible with older versions.
MRB, DO YOU NOT WORK ON SATURDAYS. I CALLED BY PHONE, I CAN'T REACH. WHEN IDE WORKS AT 7 PM, THE PROJECT IS CLOSED FREQUENTLY. IT WORKS VERY SLOWLY WHEN MAKING A PROJECT. I ALSO ENLARGE COLUMN DIMENSIONS AND BEAM DIMENSIONS. THEN I DO A GENERAL ANALYSIS. THE PROBLEM OF COLUMN-BEAM COMBINATION IS CREATED AGAIN. .I ENLARGE THE COLUMN SIZE MUCH BUT IT IS NOT AGAINST IT. WHY DOES IT SOMETIMES DEFINE INCORRECT FLOORINGS WHILE DEFINING FLOORING. I NEED URGENT HELP. GOOD WORK...
ENTERING A TOPIC IN THE FORUM I DEFINED A TITLE AND WRITTEN A MESSAGE IN THE MRB FORUM. NOW I CANNOT FIND THAT TITLE. I CAN GO TO ACTIVE TOPICS. I DIDN'T FIND IT. IT WOULD BE BETTER IF THE FORUM SIGNED A LITTLE MORE.
We do not work on Saturdays. It would be good if you read the bug reporting rules on the forum and make your notifications accordingly.
What was your unavailable message about?
"dester":i4tw3aid" said:
I think the overheating problem was not completely resolved in the last version, I reinstalled the previous beta version and I continue. It doesn't have these problems.
can you download the previous beta version... I couldn't find it on the forum... Thank you in advance.
"excalibur_24":w9itzlud" said:
MRB DOESN'T WORK ON SATURDAYS. I CALLED BY PHONE AND I CAN'T REACH. THE PROJECT IS FREQUENTLY CLOSED WHEN I WORK AT 7 PM. IT WORKS VERY SLOWLY WHEN I WORK ON THE PROJECT. THE COLUMN-BEAM JOIN PROBLEM OCCURS AGAIN. I GROW AGAIN, I PRESS THE REINFORCED CONCRETE ICON, IT GIVES IT. I MAKE A GENERAL ANALYSIS. IT GIVES AN ERROR AGAIN. I GROW THE COLUMN SIZE TOO MUCH. BUT IT CANNOT FIX IT AGAIN. WHY CAN'T WORK.
Hello, Send the project you are having problems to destek@ideyapi.com.tr, let's see together...
The project that I imported from autocad is not visible in the 3D window... I think it goes to a very far point from the origin point... how can I move it to the origin point?
1- How are the soil layers entered in the pile foundation system..? 2- Will the ranking be from bottom to top or from top to bottom...? 3- How do I find the vertical spring factor Kv value..? 4-Does the value with adhesion factor 0.45 change according to the floor..?
Hello, enter the move command and select all the drawing. After selection, press the right button. Click a base point with the left button. Press X on the keyboard. type 0 from the keyboard. Lock the value with enter. In the same way, enter Y 0. Click any point on the plan with the left button. Your project will be moved to the origin. Make the latest zoom borders. Good work...
"nahroyo":jxu6bw6y" said:
The project I imported from autocad is not visible in the 3D window.
