OguzhanSoydas
Re: Opinions about using ideCAD Reinforced Concrete 8 questions
Thank you, you have been very helpful. Good work.Hi OguzhanSoydas --Check Ritz method --1. remove the flood marks of the curtains in the basement. IT IS SOLVING BUT IF IT WAS ME; My suggestions --Build on the embankment, --I avoid stepping on the foundation of the building --Ladder bracing is missing, it's not a customary practice to sit on a console on the mezzanine inside the building --Check the wall loads --Let the beams center on the columns, not more than d/2 -- make the narrow side of the columns 30 cm --Correct errors in geometry control Take it easy Ünver ÖZCAN
