Opinions questions about the use of Reinforced Concrete Design
Re: Opinions and questions about using ideCAD Reinforced Concrete 8 Thank you for your attention. It would also be convenient for us if there is an option to detail the basement perimeter curtains outside while getting the column application Plan, as in the old versions. When we take the rigid floor number one below, the curtains can be drawn outside, but they are detailed outside in the columns to which they are attached. It gets very confusing in projects with narrow apertures, even though I get 1/25 scale. In addition, all the details are applied outside, and we carry the unreinforced 1/50 scale copy of the curtains from there. Sent from my iPhone using Tapatalk
Re: Opinions about using ideCAD Reinforced Concrete 8 questions Hi, Is it possible to define rib beams at the console end and sides of the ribbed slabs defined as cantilever by the program? The related feature is also available in sta4 and it saves the user from making corrections to the mold plans.
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions I can increase the width of the foundation as much as I want in the retaining project I have sent attached, it gives the collapse factor as 0. What is the reason?
Re: opinions about using ideCAD Reinforced Concrete 8 questions hello ; Dear interested parties, I am trying to draw arc curtains with idecad8, but there is no arc curtain drawing, first we draw an arc and then turn it into a panel, in this case we need to enter the number of parts. In the number of parts I have given to capture my curvilinear shape, the panel length decreases to 80-90 cm. I encounter the statement that it cannot be less than 7 times.
Re: Opinions and questions about using ideCAD Reinforced Concrete 8 [email protected] I sent my project to [/email] because it is a private project, I may have made mistakes in the modeling .can you check and come back?
"vuralmüh":1gp3t30f" said:
hello ; dear interested parties, I am trying to draw an arc curtain with idecad8, but there is no arc curtain drawing, we draw an arc first and then convert it to a panel. I need to enter the number of pieces. In the number of pieces I have given to capture my curvilinear shape, the panel length decreases to 80-90 cm. In the geometric control, I encounter the statement that the panel length cannot be less than 7 times the panel thickness, what should I do in these cases?
Hello, Warning given in geometric control , is just a warning. You may ignore it.
I sent my project to [email protected] because it is a private project, I may have made mistakes in modeling. Can you check and return?
Modeling and data entry You will be notified of any errors. Good work
Re: Opinions and questions about using ideCAD Reinforced Concrete 8 I downloaded idecad 8 demo, when I open the program, I can't make any drawings on it, can you help?
Click on the New line in the project menu , are you opening a drawing window?
"vuralmüh":3941y22v" said:
hi ; I have encountered such a problem in basement curtains, what is the reason why the reinforcements are thrown at such ridiculous intervals? Also, are the longitudinal reinforcements missing?[ /quote] Hello, can you add your project?
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions hello Mr. Yasin, the file is attached. I am facing this problem in basement curtains, good work.
Re: Opinions about using ideCAD Reinforced Concrete 8 questions Hello, You tried to create a curtain close to the arc form with short curtains. In such cases, drawing problems may arise. You can edit the column application plan with the 2D drawing tools.
Re: Opinions and questions about using ideCAD Reinforced Concrete 8 I am doing a project in the new version. Body reinforcement comes out to the cantilever horizontal beams. Also, it does not always accept cross beams on the foundation and floor.
"Tombombadil0785":2uj1beuw" said:
I am making a project in the new version. The console horizontal beams are equipped with body reinforcement. Also, cross beams are not always accepted on the foundation and on the floor. /quote] Hello, if you can send your project, let's review it?
Re: Opinions about using ideCAD Reinforced Concrete 8 questions There is no problem on the continuous basis. It's on the floor joists. Is there a way to make the bottom reinforcements different in continuous beams of different heights?
"YasinTezel":30nck6bk" said:
"Tombombadil0785":30nck6bk" said:
I am making a project in the new version. Body reinforcement comes out to the cantilever horizontal beams. Also, it does not accept cross beams on the foundation and on the floor all the time.
Hello, If you can send your project, let's examine it?
The problem has been solved. Thank you for your interest.
"YasinTezel":3furp13e" said:
Hi, You tried to create a curtain close to the arc form with short curtains, In such cases, drawing problems may arise. you can edit it with drawing tools.
What is meant by 2d drawing tools? Is the number of reinforcements sufficient? What kind of arrangements do I need to make?
"vuralmüh":ah5vgbhj" said:
"YasinTezel":ah5vgbhj" said:
Hi, You tried to create a curtain close to arc form with short curtains, This In such cases, graphic problems may arise. You can edit the column application plan with 2D drawing tools.
There is no possibility of automatic opening of spring curtains in the program. Do it with the program's 2D Drawing possibilities. Reinforced concrete is computationally correct. What Yasin mentioned is valid only for drawing.
"Tombombadil0785":g1dwhux5" said:
Continuous foundation is OK. Floor beams have it. Is there a way to make sub-reinforcements different in continuous beams of different heights?[/ quote] For beams that are not constantly drawn, first "Reinforced Concrete Design/Parameters/General Reinforced Concrete Parameters / Always accept beams with small angle difference"[/u Enter a value in the ] dialog. Further adjust the viewing directions of the beams (e.g. ground floor beams K14, K17 right end, left end). To do this "Change/Object Edit / Beam -foundation /Beam-Foundation Set Direction" command.
