Hello In the program, the drawings of straight-armed stairs are made automatically."vuralmüh":1h2spl8r" said:hello, I'm drawing the ladder, but when I get the drawings, it doesn't draw properly. Is it from me or from the source program, can you help? It's marked in the picture named screenshot2. What is the reason for drawing the axis of the account from one end to the other on the floor?
Revolving arm and revolving step ladder with pictures attached. You need to edit using the possibilities."vuralmüh":1yhwzshz" said:when you say it is done automatically, ?
Hello, P10 panel on the basement floor " When you deactivate the line "divide by intersections" and re-enter it, analysis can be made in your project. Other determinations; -Beams are drawn on the P01 panel in the basement floor. Since the P01 panel continues on all floors, no beam should be drawn on it. -K17 beam should be connected to the P01 panel at the node point. -K05 beam P01 -The rib tooth is not fully formed on the side of the K07 beam of the D05 slab. Change the starting tooth width. For example Make it 20 cm. -Define panels P09 and P10 at the same angle as P01. Good work"kbrbk":1mmlut9q" said:Good day guys, I'm new to using the program, I could use the net and solve the problem for other errors, but I couldn't understand it. When it comes to the analysis section, it stops, freezes and does not continue the analysis. It does not terminate. I tried in other idecad files, the analysis is being done. The problem is not in the analysis, but in my drawing, but I do not understand where it is because it does not say anything. Can someone help?
In the project, as the floor edge of the D04 slab with its name on the ground floor is not connected to the K17 beam from the nodal point, the floor nets do not form correctly. When this error is corrected, it will be seen that the analysis results do not change. Improvements have been made so that they will make fewer mistakes Note: You did not reply to us about the issue you said you could not do about object selection. .idecadsupport.com/forum/viewtopic.php?f=5&t=4303#p19509[/url]"izmirlimuhendis":4yvjvhef" said:when I analyze the attached project, I see that only 2 columns are giving error on the ground floor. The number of errors increases to 21. Again, when I do nothing and analyze for the 3rd time, this sfeer error number is 13. When I turn the event into funWhen I analyze it for the 4th time, I see that the number of errors is 12. I wonder where is the problem, can you help?
"cüneytazak":dl75g9c0" said:Hi there. According to the regulations, the stirrup spacing can be 10 cm in the compaction zone in a column whose short side is 30 cm. One reason the program gives 8 cm is Is there any? .10 cm and 30/3=10 cm values are the upper limits, according to the regulation, the stirrup spacing can be reduced to 5 cm.
