nurgulkaya
Hello there; Could you send an e-mail to destek@ideyapi.com.tr, briefly describe the problem for the reinforced concrete section. Good work.
Ms. Nurgül I agree with what you said. As you said, normally when it is done separately, it is acted as an external load and this is the solution. But in this solution, the mass of the steel structure is neglected. for the building the actual dynamic behavior is not calculated. I think the administration's request is to see the static loads on the beam. That's why I said. Of course, it is debatable whether it is necessary to activate this feature. That's why I said "can be shown" in my previous post"nurgulkaya":2u3pbyfz" said:Hi; Is the reason for the request of the inspection mechanism because the general steel - reinforced concrete solutions in the country are made separately and the steel results in the superstructure are given to the reinforced concrete elements as a support reaction and the reinforced concrete design is made by including these loads and reported in this way? By the way, the important thing is to determine the reason for this demand. In the programs that model and solve together, there is no such thing as the load of the element coming from the top, since the structural system elements are solved in one go. All of them are the internal force output as a result of the analysis. If we can understand the logic of your request, it will be more convenient and the program We can find a solution according to the logic of the logic, please, can you briefly explain the reason for this request?
TDY-2007 Article 2.3.2.4 of the earthquake code. (b) In case the column sits on a beam supported from both ends, this will occur in all sections of the beam and also in the direction of the earthquake considered. to the nodes where the beam is connected b In all cross-sections of the other beams and columns that converge, all internal force values resulting from the combined effect of vertical loads and earthquake will be increased by 50%. is called. For this reason, the loads on the reinforced concrete beam on which the steel beam sits and on the other continuous beams and columns should be increased by 50%. Is this augmentation process carried out in our program? As far as it is seen, incoming downloads are only increased by 100% as DL and LL. Where can it be observed in the reports that the earthquake loads are increased? During the control of the related project, we are asked to prove it by the Chamber of Civil Engineers."nurgulkaya":zd5owc8e" said:Hi; Is the reason for the request of the inspection mechanism because the general steel - reinforced concrete solutions in the country are made separately and the steel results in the superstructure are given to the reinforced concrete elements as a support reaction and the reinforced concrete design is made by including these loads and reported in this way? By the way, the important thing is to determine the reason for this demand. In the programs that model and solve together, there is no such thing as the load of the element coming from the top, since the structural system elements are solved in one go. All of them are the internal force output as a result of the analysis. If we can understand the logic of your request, it will be more convenient and the program We can find a solution according to the logic of this request, please, can you briefly explain the reason for this request?
Working on the development of the report on B3 irregularity for steel structures to be done noted. Good work."2m project":1fjvumc0" said:"Is the reason for the demand of the inspection mechanism because the general steel - reinforced concrete solutions in the country are made separately and the steel results in the superstructure are given to the reinforced concrete elements as a support reaction and the reinforced concrete design is made by including these loads and reported in this way? " Yes, you are absolutely right in this determination, but there is a shortcoming in the program: 1- While B3 irregularity detection is made automatically for reinforced concrete columns resting on beams, this detection is not made for steel columns. 2- For reinforced concrete beams, the names of columns or beams on which they are supported are written in the reports, but not for steel beams 3- If a report on B3 irregularity is developed and information such as the element causing this irregularity (name, which floor is defined, which beam is supported), doubts will be eliminated.
