Hi guys, I thought of posting a new model and result table for the sake of tidier and continuity of information in this topic. The model is simpler and the analysis time is not so long as to hinder your work. The model is v10. I created it based on the black template 03. I set the floor and curtain mesh width to 50 cm. The link on which the model is loaded will be permanent, so it will not be deleted. As you share your results, I will add them to the table. At least for a while
Even if there are 20 results in the list, I think it is enough. After opening the model, just press the analysis button without changing any settings
Model:
Result table:
When you click on the processor name in the result table, you can see its properties. NOTE: It may be more useful if this message can be moved to the top of the thread by the administration.
