saridurmus
Yes, I didn't change any settings. I did this to compare the analysis time.
The more GHz, the more meatballs. 3-4 years old"saridurmus":q0b3qi4b" said:I have an old laptop, so the analysis time is 16.69 minutes, so I still have a sufficient computer.
Do not solve this system and every system as a semi-rigid diaphragm at the beginning. Design the system, first deal with the column curtain beams. If you do it in the types specified in the regulation If the elastic diaphragm is a structure that needs to be dissolved, dissolve the semi-rigid diaphragm in the final step."myanswer":2dkasitz" said:I modeled the first project I sent as a single foundation with 3 blocks, combined dilatation in basements between blocks, analysis time 135 minutes, 3 days, I haven't been able to get past the analysis part yet.Opening, closing, saving the project, looking at the analysis model, deformations The transition times between these are also very long. Computers are too effective during the project production period. It is necessary to renew the system now
as you mentioned in the last step, but the errors in the column-beam junction area are very tiring. In order to eliminate the errors in the columns (B), I solve the reinforcements in the beams as semi-rigid and reduce the reinforcements, then I change the dimensions of the columns and beams in the system, their misalignment, and analyze again. The process took days, so the conditions in the column-beam junction area got worse."Ismail Hakki Besler":321wa794" said:Do not dissolve this system and every system as a semi-rigid diaphragm at the beginning. First design the system, take care of the column curtain beams. If your structure is a structure that needs to be dissolved by the elastic diaphragm in the types specified in the regulation, I have determined the semi-rigid diaphragm solution"myanswer":321wa794" said:I modeled the first project I sent with 3 blocks, combined dilatation in the basements between blocks, as a single foundation, analysis time 135 minutes, 3 days, I haven't passed the analysis part yet. Opening, closing, saving the project, looking at the analysis model and deformations takes too long. computers are too effective during project production time, now it is necessary to renew the system
When semi-rhythm is resolved, the program looks at both the rigid diaphragm results for the columns and the semi-rigid. It looks at the most unsuitable situation. See the B errors by solving the rigid diaphragm. En Check once again by marking semi-rigid in the last wizard. In this project, the blocks are separated by dilataston. You do not have to solve three blocks in the same project. Also, you do not have to solve semi-rigid solutions. Refresh your system also. But still follow this procedure. Share it here too.Let's test the speeds."myanswer":tgi81boc" said:as you mentioned, I determined the load-bearing element sections, but the errors in the column-beam junction are very tiring. In order to eliminate the (B) errors in the columns, I solve the reinforcements in the beams as semi-rigid and reduce the reinforcements, after that, I change the dimensions of the columns and beams in the system, their misalignment and repeat I'm doing analysis, the process took days, so the conditions in the column-beam junction in the regulation got heavy.
