Hi Suggestion project is attached.
INFO NOTE: In this case, there is an error in the project no, but it would be better if you combine the outer columns as a frame (In my province, if the outer columns are not combined as a frame, the project will not pass the inspection.) Ünver ÖZCAN"batuhann28522":w2axnvtv" said:Easy. I can't solve the problem of column-beam shearing safety problem that I am constantly experiencing. Can you help. The project is in the link below. Thanks for your attention
