Hi
"duriy3":1qhao3i4" said:
I am getting Nmax errors on beams in my project. When I give very large dimensions to the beams, only the errors are resolved. When I solve the ladder outside the building, the number of error beams decreases. Is there any other way I can troubleshoot? Also, I couldn't fix the cut-safe error on curtain P01 in the basement. can you help me? I would be very grateful if you could indicate what you see missing in the project in general
My suggestions: --Fix the errors in the geometry control, --The ladder is not supported. (all edges seem to be recessed.) If you do not support the ladder correctly in the semi-rigid solution, the horizontal displacements of the building will be incorrect because the place where the ladder is located is rigid (contained). Increase the thickness of the P02 curtain, if not, increase the curtains on the sides (or add additional curtains). . Increase the width of the K11 beam in the basement, --Make the concrete value C30, --Add flooring for the elevator machine, Ünver ÖZCAN
