eissenhover
Re: PROJECT DESIGN AND PROBLEMS ENCOUNTERED
...Hello Mr. Suat. I have a question, you know, if 70 or 75% of the earthquake (the rate is not important for my question at the moment) carries curtains or if it overflows, it would be good. What I want to ask is, how do you determine this in the suki program (idecad). I don't know how much of the earthquake force is, do you give the command to the program so that the curtain will carry that much. Where do you look at the alpha value your friend is talking about. Arkads alpha dropped to 50 percent or so when he lifted the curtain, he said. Where is he examining it? If you could help with this situation, I would greatly appreciate it"coskun3561":1zdtrqvo" said:Mr. Suatyy Can you explain more about the case of not forming frames? Let's be careful in the next projects. Are you talking about the case that the columns are not connected with the beams? I can't stretch the curtains, there are ventilation windows in those parts. I was thinking of reducing the beam sizes by doing stiffness reduction as you said, I will follow your advice. Isn't the raft basically 110 cm too high? When I look at the calculations, a 70-75 cm raft saves with additional reinforcements. I tried to solve it with the rafter raft, but it did not save even though the sections grew too much. Regards, take it easy"suatyy":1zdtrqvo" said:Mr. Coşkun, there are frames in your structure. I said that 75% of the earthquake was carried by the curtains in case the frames could not be formed properly. There is no need for this for this structure at the moment, but I saw a lot of studs in the structure, especially in front of P05 and P06, there were studs at a short distance. I recommend that you eliminate these studs by lengthening these curtains, where shear cracks may occur. If you can reduce the other studs by extending the columns or adding additional columns where possible, your structure will be healthier. The curtains in the building are not bad, evenly distributed. This situation is good, I think there is no such exaggeration. Your periods are also compatible for a 10-floor building. I think some of the beams were larger than the column he stepped on to save them from cutting. This is not a pleasant situation. Either increase the column to these dimensions, or (I suggest) accept that such high shear short beams will crack and perform a cracked section stiffness reduction. (0.4 EI) so they take less impact and you can recover with a smaller size. I think you will make raft the foundation. I would not recommend making a section less than 110 cm. Note: They do not accept 20 in the butt beams at the ends of the closed overhangs, you need to make 25. take it easy.
