What I want to have in Idestructure Hello, I would like to share some things that I want to have in Idestructure. 1) Whether or not the internal dimensioning is drawn in the mold plan is optional or given as a block as in 5.55. I do not use internal dimensions in my projects and it is difficult to delete one by one each time. At least if it is drawn as a block, we can select and delete it with one click. 2) While drawing the beam section in beam expansions, writing the measurement values in 2 stirrups in double stirrups causes confusion. It's hard to organize this mess in every project. Also, in deep beams, it would be better if the top measurement value of the stirrup is written on the stirrup arm in the drawing of the beam section. 3) When we make a similar floor application in the beam expansions, the number of reinforcements and the total length of the reinforcement are drawn under the reinforcement line. There is enough space on the reinforcement as seen here. Where it is not, the text can be reduced a little to fit it. 4) It is necessary to draw the elevator bucket detail. 5) We want to solve the tunnel formwork project using idecad. (Fictive beam is not available, we cannot use mesh reinforcement on the curtains.) 6) To be able to sit vault and dome-style structures on beams and to make their calculations interactively. 7) To be able to make the calculation of the well foundation interactively with the building (taking into account the weight of the building). 8) To be able to calculate the hollow column (circular, rectangular, polygon) and take the drawing. 9) Making inclined slabs by leveling (for stair landing and parking ramp) 10) Giving inclination in the openings of oblique beams and drawing the lengths of inclined beams and inclined slab reinforcement according to their inclined state. In the Chamber of Engineers and in some municipalities, they cause problems in this regard. 11) Displaying all errors in the project at once. 12) Some errors that exist in the project do not appear in the reports. (File attached) There are no reports of weak column and shear safety errors in the columns. 13) Possibility of entering beams to the open side in U-Type polygon columns (elevator bucket). 14) Automation of formwork plan section and foundation plan section. 15) Nonprismatic beam making, analysis and drawing. Take it easy everyone.
