What would you like to have in ideCAD Static?
I want stepped foundation with detail drawing. Recently, it has started to be needed frequently in our projects.
BEAM EXTENSIONS When will these deficiencies be corrected? Writing the elevations in the beam expansions. Showing the inclined beam expansions as inclined. Showing the reinforcement expansions accordingly, assuming that the inclined and straight beam continuity continues.
I want the curtain spacing to be able to be checked according to the 3.6.8 condition in the regulation.. also, I want the meshing that we see in the 3D frame to be active when we space the curtain, and I want to be able to open the curtain space from where I want in 3D ... we can do all of these with beautiful curtains and overlays. I think it would be great :D
As in AutoCAD program, I define a shortcut for each command and instead of selecting it, I enter the command with letters, but these shortcuts are reset when I update. There is a txt file in the Autocad program, so I can copy these records to any PC we want and continue with the shortcuts intact. Is there a way similar to this or I want a solution.
ideCAD customizations (shortcuts and toolbars) are stored in the windows registry for each user defined in windows. There is a possibility to get these shortcuts using the registry editor, but wrong action can cause registry problems. As of version 6.0054, we have changed the registration structure and your customizations will not be lost in new updates.
Hello there; When we view the structure as a 3D frame and simultaneously rotate it in 3D, the structure is rotated as a Wire Frame. I think this is because you want to increase the performance of the software, but this creates problems for those who want to examine the 3D frame in detail, like me. In solid modeling, this can be beneficial in terms of performance, but in 3D Framework I don't think it will add much performance. I would appreciate if you could disable this feature in 3d Framework. NOTE: I am using a 4 core intel processor and 2 gb ram.
problem with your video card. It happens like you said on some computers in the office. but this is not the case on my current computer.
HELLO FRIENDS, SINCE THE 6 VERSION WAS FIRST COMING, I DID NOT GET ANY APPROACH OR HELP EVEN IF I REPORT THE SAME PROBLEM MANY TIMES. AM I DOING WRONG? WHEN MY EARTHQUAKE CURTAINS IN MY SYSTEM CROSS OR CONNECT AT ONE END WITH BODRUM SURROUNDING CURTAINS ON THE BASEMENT FLOOR, THE SIZE OF THE EARTHQUAKE SCREEN IN THE BASEMENT IS CHANGED. THIS CHANGE CAN BE SEEN IN THE CURTAIN DETAILS. THEREFORE, SOMETIMES, SUCH AS 25x175, MY EARTHQUAKE CURTAINS SHALL BE REDUCED TO 25x150 DIMENSIONS, SUCH A HEAD CANNOT BE CREATED ON THE BASEMENT FLOOR, AND ALSO CHALLENGE WRONG READINGS. WHEN THE ACCOUNTS ARE EXAMINED, WE SEE THAT THE SAME SIZE HAS BEEN TAKEN. TO CORRECT THIS, WE PLAY ON THE BODRUM CURTAIN FAILURE, THEN FIX IT AGAIN ETC.. CAN A SOLUTION BE GIVEN TO THIS ISSUE? GOOD WORK EVERYONE...
"Admin":buy6054h" said:
ideCAD customizations (shortcuts and toolbars) are stored in the windows registry for each user defined in windows. It is possible to import these shortcuts using the registry editor, but an incorrect operation can cause problems in the registry. We have changed the registration structure since version 6.0054 and the customizations you have made in new updates will not be lost.
I gladly installed version 5.0054, but I don't know if the result is frustration or I don't know if it helps me, I need to spend at least 2 hours for my shortcuts.
"muhendismy":115fvkll" said:
"Admin":115fvkll" said:
ideCAD customizations (shortcuts and toolbars) are stored in the windows registry for each user defined in windows. There is a possibility to get these shortcuts using the registry editor, but wrong action can cause registry problems. We have changed the registration structure since version 6.0054 and the customizations you have made in new updates will not be lost.
I gladly installed version 5.0054, but I don't know if the result is frustration or I don't know, I need to work for at least 2 hours for my shortcuts to help this issue. I don't want to deal with it over and over.
After 54, the program will take it by itself... Also, if the shortcut customization job takes 2 hours of your time and the situation is frustrating for you, send your PC to me and I'll do it for you.. Do it one more time. Is it that hard?
"HakanŞahin":14mos9q9" said:
"muhendismy":14mos9q9" said:
"Admin":14mos9q9" said:
ideCAD customizations (shortcuts and toolbars) are in the windows registry for every user defined on windows It is possible to get these shortcuts using the registry editor, but a wrong operation can cause problems in the registry. We have changed the registry structure since version 6.0054 and your customizations will not be lost in new updates.
I gladly installed version 5.0054, but the result is frustration or me? i don't know please help with this issue i have to work for at least 2 hours for my shortcuts i don't want to deal with it many times I'll do it for you.. Do it once again, is it that hard?
No need, I solved it with Regedit.
Quantity files should be exported to excel... it would be very useful for adding on. excavation calculations must be made by entering at least the corners of the land, the leveling of the corners of the building, and the natural ground levels of the building... this means that the application can also be entered into the idea. jeans etc. if it is possible to enter the foundation, etc. The engineer can be informed by adding warnings. foundation sections can be drawn more clearly, including the ground.
I think it is necessary to check the stapling in continuous foundations as in the raft. The main control stapling, where the foundation height is determined, and the program do not give an error even on a 50 cm high foundation in a 10-floor place, since there is no stapling control. good work
Sections are not taken properly in spiral staircases. In the drawings we have to draw the sections by hand. Are you going to make any corrections to the stairs?
It would be very nice if the curtains had the opportunity to make their heads eccentric, if the curtains were not divided on the axles. A single curtain is defined as 2-3 curtains. Can't we do this one act? In particular, I want to take reinforced automatic section in raft foundation drawings. I want the column menu to be improved. When the column on the bottom floor is minimized, I want the columns on the upper floor to be reduced in the same way.
With the change column size command, you can change the size of the columns in the entire floor at once.
"Oznb":2ppesea4" said:
It would be very nice if the curtains had the opportunity to make them eccentric in their heads. It would be very nice if the curtains were not divided on the axles. A single curtain is defined as 2-3 curtains. Can't we make it a single curtain?
You mentioned an important issue. ..
Can you describe the problem you are experiencing here in a little more detail in order to understand correctly? The program takes this type of curtains into account in reports and drawings. Where are you having trouble?
Hello there; I have a few suggestions that I think would be nice if it worked. Is it possible to switch between the COLUMN WIDTH and COLUMN LENGTH boxes in the 1. Column menu with the tab key? 2. Is it possible to make an arrangement where we can see the floors we created in our project and the drawings related to these floors in the building tree and open that window with one click? I wish you good work...
