Steel trusses cannot be recognized in the system. I solve the steel structure in Sap2000 in the Idecad program. In İdecad program, you can enter values such as vertical load and moment to the nodal points in 3D frame mode."aksa":2reuniyp" said:Hi, how can we define 1-steel truss roof beams in the system? Good work..
Details of the mezzanine elements defined in the normal floor plane can be taken with their names and the floor index they belong to. If you define the system you mentioned as a mezzanine floor as a different floor, you can do whatever you want. Is there a reason why you don't define the mezzanine as a different floor?"erryan":19ecfsab" said:I would like to state that it would be very good for users to be able to perceive the mezzanine formwork plan and mezzanine beams as a separate floor in mezzanine buildings, and draw both the floor plan and the beam extensions as in normal floors
Could you explain the problem with an example? Good work..."erryan" :19ecfsab" said:a floor edge that I entered in the formwork plan affects the beam on the mezzanine level, which creates a problem.
Hello, In the example you sent, the data entry was not appropriate. While editing the data; 1.) Enter the normal floor beams and the floor edges and all floors connected to it and finish the process for normal floor elements. 2.) Then you enter the elevations of the mezzanine beams but turn off the "divide by intersection" mode when entering beams. This process will prevent unintentional splitting of your mezzanine beams. That's the problem with the beams you can't see. Examine the data "Mezzanine Building_system1.cde" that I added as an example. If there will be flooring in the middle floors (for the formation of a rigid diaphragm), you can define the similar system by opening a different floor. In this case, you will also have the opportunity to edit the formwork plan. Examine the "Mezzanine Building_system2.cde" data. As a result, these notifications will be evaluated. However, I wanted to draw your attention to the issues I wrote... Good work..."erryan":1b0jhzmh" said:In the example I sent attached, the floor edge that I used on the ground floor also affects the beams on the mezzanine, so we can't see the reinforcements of these beams in the reinforced concrete beam reinforcement window schematically, and we don't have the chance to intervene, as well as the drawings of these beams in the beam expansions. we have to buy it with different methods, the beams we cannot see are the K3-K4-K7-K8-K11-K12 beams in the mezzanine.I wonder if it is possible to level the floor edge as a solution.Also, when we have to make a mezzanine for architectural reasons, is it possible to get the mezzanine formwork plan separately? .
Hello, Send your project to destek@ideyapi.com. Send it to tr."yilmazozaktan":15cwe78a" said:I couldn't add because the project is over 5 mb compressed. How can I send it to you? Good work.
Settings->Drawing with the General Settings menu command You can set your limits."ciyamee":f5qy8ar5" said:mrb friends, I installed the demo version. I wanted to enlarge the drawing area to start the project, but I couldn't. I would appreciate it if you could help me (dimensions of the building 50mx50m)
