HakanŞahin
Administrator
You stated that you want to work 1 to 1 on the project. When we measure the distance between the two axles, 120 cm turns out to be 120 meters. When you import, for example, a basic application plan in the program, the drawings are already created 1 by 1. In order to keep 120 cm as 120 cm, it makes more sense to use the default value of 1/100 instead of 1/1 while designing the layout. Design 1/100 and measure the values, you will realize that you are designing 1 to 1 of all dimensions. When you arrange the layouts according to 1/1 scale in layout design, you enlarge the whole system 100 times. As a result of this situation, the size of the map has grown a lot. The problem stems from this. For the solution, make the layout design 1/100.
