Dear Tawakkul, The issue here is not the number of floors. By accepting ductile behavior and reducing the earthquake load, a non-ductile joint due to this type of connection faults Even if it's a single storey, let's not make a mistake like this. There are many single-storey or two-storey buildings destroyed in the Erzincan and Düzce earthquakes. The problems and mistakes in the regulations do not end. There will be problems in the new one. As I mentioned before, the regulations are designed to minimize the risk of making fatal mistakes This is not the only conflicting point. Let me just give you one more example, when calculating the shear strength Vr, there is a coefficient Vc for the concrete admixture. For different values of this coefficient, see TDY in TS 500. You go to TDY, the different values of this coefficient at the relevant point He says, see TS 500 for this. Between two regulations, you come and go. What would you do in this case? Wouldn't you take this coefficient just because you didn't? Of course not. In this case you get whichever coefficient puts you on the safe side. One more example. You know, it is not possible to recover the shear safety of column-beam junctions without interfering with the architecture. Any beam that sits on the columns from the side and at the end of the column does not save this control. Is it because it really didn't save? No, the Regulation is a deficiency in the formula. Here, Ve is expected to be greater than Vr. For Ve, a shear capacity is calculated by taking the lower and upper reinforcements of the beam according to the earthquake direction. but for Vr, only the concrete cross-sectional area of the column that the beam pushes is taken. However, in order to prevent shear cracks to be controlled here, stirrups are also placed in the area of the columns corresponding to the beam, but these stirrups are not taken into account in the calculation of Vr. It is a formula prepared by staying on the very safe side. So, are we going to skip this check just because we know the deficiency in this formula? No, because the placement of beams in this area has not yet become a habit for all blacksmiths and we do not trust the control mechanism that much yet, so we do this again to stay on the safe side. In short, I think all these controls are necessary. Here, we must spend our energy to find solutions to such applications that cause errors in building behavior. A blacksmith who could not place the column stirrup we mentioned said to me, 'I cannot place this stirrup here, if you know, let's put it on the show'. At that moment, the man was right, asking for a solution at this point. I thought a lot and found a solution and had it done by the master. Greetings
