Re: PROJECT DESIGN AND PROBLEMS ENCOUNTERED Dear NYILMAZ; Thank you for your participation... Unfortunately, the municipality I am affiliated with does not have any restrictions or controls in adjoining structures. Even worse, when one of the two adjacent buildings needs to be demolished, there is no action taken. Let alone the control of the impact effect, in a building to be built adjacent, even the level differences between the floor levels of the existing building and the building to be built are not mentioned, even though this situation constitutes a violation of the order in terms of architecture. That is, there is a building with floor elevations of +4.00, +7.00 ..., while in the building next to it, the floor levels are +3,00, +6,00 .... The columns do not hold each other, the building beams cut the columns of the other structure.. As you know, in the earthquakes experienced, in adjacent structures, beams were cutting columns due to this contradiction, and these cuts were occurring because the distance between the two adjacent structures to oscillate was not maintained or because there were elevation differences between the structures. As a result, I can say that there is no control, unfortunately, we always follow behind at the point of taking a lesson. As for what to do, if we do not have any architectural constraints, it may be possible to design the columns in a way that the columns are back to back on the adjacent facade, leaving a dilatation joint above the maximum displacement amount of the structure. If, architecturally, the columns do not come back to back on the adjacent facades and there are elevation differences as I mentioned earlier, the facades can be joined by making closed protrusions after moving away from the adjacent facades and applying the columns (maintaining the minimum dilatation). Let me end by asking one more question
... It is appropriate to increase the "live load 150kg/m2", which is foreseen by the regulations and our teachers, on floors that carry non-bearing (partition walls) walls. The problem I am facing now is; We have a floor, the columns are connected to each other, you have created very beautiful frames, but in the architectural plan, there is a 20-inch wall in the middle of the floor you have created. What the municipality said, there is a 20 wall here, so you have to throw beams
when a beam is thrown there, there will be a stud beam, the frame will not be formed, moreover, instead of throwing beams there, I increased the live load by 150 kg / m2, or I created a linear load where the load is on that floor( It is a futile effort to say ....etc instead of beams (wall load of 20). Because you cannot explain, it is such a strict memorization that it does not break... Does your municipality have any imposition on you, or how is the practice in various municipalities at this point? ... thanks for sharing ... good work, respect...
